Color correction
Sensitive areas are always taken into consideration on a delicate job like this and masked.
Refinished, color was right on but the texture was off, a bit too much fine peel or structure...
Structure and minor orange peel leveling on a repainted panel
Thoroughly scuffed properly with the utmost care, this area is now ready for the next step.
Proper restoration
50/50 shot
Protection!
Thank you for the call earlier today Seymore, as I mentioned to you I would post some pics.....above are some fresh pics from a member of the C6 Forum, Richard who also reached out to me to handle the needs on his Monterey Red vert.....
Detailer that will ever touch my car unbelievable work. Thanks Dave.
seymore
I truly appreciate your comments above, and so long as you stay away from the "Duster" she will stay looking mighty fine! What a transformation as you will see from the photos, this Monterey Red Metallic just totally came back to life.
A total of almost 9 man hours were provided just to restore then preserve this gorgeous color....
Before photos showing the damage that has been created over time on this very soft tinted clear coat. IMO and I have 30 yrs of doing and seeing this over and over.....The Duster is just moving around these abrasive particles which just score your finish!
Time for a thorough prep and paint decontamination
Every Vette that comes thru gets some engine bay TLC.....
Up and close, here was my initial test area, the "goal" to level out all the surface defects taking the "least" aggressive approach. Here is a 50/50 photo showing the extreme difference in the first step using the proper procedure!
Various lighting techniques used to achieve the perfect results.
Finished photos
If you let Dave work his magic on your car, you'd have to change your CF user name to newC5...
