test
Old Sep 11, 2005 | 01:23 AM
intel55's Avatar
intel55
Default test
Remove the side cover and then these 3 nuts. This applies the right and left side.
Here are the three nuts you are searching for. They are under the plastic panel that you just removed and under the wires. The top nut is easy to see. The other two are to each side under the black metal. You will need a 6" extention to reach them.
These two top bolts are the last two to install. Push them through the plastic and tighten them in.
