test
Old Oct 22, 2006 | 11:36 AM
HG's Avatar
HG
Default test
test MAINTENANCE RECORDS & OIL CHANGES
Tire Size Front 255/45 ZR17
1993 Corvette Ruby Purchased 1/12/2006 Rear 285/40 ZR 17
Miles at Purchase 7690 New Tires 7475
Present mileage 11800 Present mileage 11800
Usage 4110 Miles Usage 4325 Miles
OIL CHANGES MILEAGE DIFF New Air Cleaner
8/13/2003 6709 1/20/2006 7725
2/16/2005 7475 766 Present Mileage 11800
3/23/2006 8085 610 Usage on Filter 4075
REPAIRS MADE BY YEAR
2005 MILES COST
REPLACED OPTI SPARK DIST. 2/16/2005 7475 $797.00 Failed gasket on water pump caused problem
REPLACED ANTI FREEZE 2/16/2005 7475
2006 DATE MILES COST
New Battery 1/16/2006 7710 $49.00 Mechanical Old Battery was 4 years old. Changed to prevent future problem.
Intake Manifold Gasket 1/24/2006 7731 $406.29 Mechanical Only small wet spot. Repaired to prevent future problem.
Sill Plates 1/29/2006 7760 $60.00 Cosmetic
Splash Guards 1/29/2006 7760 $80.00 Cosmetic
Transmission Fluid & Filter 2/21/2006 7993 $125.17 PM Service
Changed Rear Fluid 2/22/2006 7993 $98.22 PM Service
Flushed Brake Fluid 2/23/2006 7993 $81.52 PM Service
Check SYS code on dash 2/24/2006 7993 $37.50 Mechanical Intermitten Prob. Not flashing now Code 71
Md. Emmissions Test 2/21/2006 8023 $14.00 Misc. Passed
Balance all four wheels 2/23/2006 8085 $91.00 Mechanical To remove lead weights on outside of rims.
Replaced Rear curtain Hooks 5/1/2006 9200 $20.95 Cosmetic R/S broken changed both
Replaced Seat Bladder diaphrams 5/12/2006 9500 $4.95 Mechanical Peplaced both diaphrams in pumps.
Install Magnaflows Mufflers 5/24/2006 9530 $344.00 Cosmetic Magnaflow # 15623
93 Corvette Service Manual 6/10/2006 $26.10 Misc. ebay purchased
SYS Flashing in display 6/19/2006 9576 $0.00 Found loose ribbon connector in DIS module
Repaint Front Bumper Fascia 6/26/2006 10175 $275.00 Cosmetic Fascia somwhat faded from sun.
Misc. Seals 6/28/2006 10205 $84.93 Cosmetic Black out Kit and roof seals Console plate
Check engine light on 7/18/2006 10620 $240.05 Mechanical Replaced two knock sensors.
4 Wheel Alignment 10/10/2006 12000 $82.49 Mechanical Only adjustment to toe on rear wheels.
COST FOR THE YEAR. $2,121.17
