test
Old Nov 17, 2006 | 01:43 AM
bweaver999's Avatar
bweaver999
Default C1 and C2 FAQ thread
C1 and C2 General FAQ
This FAQ contains links to CorvetteForum threads that pertain to items of interrest to both C1 and C2 Vettes. We have not filtered or agree with some of the content, but do plan to provide links to varying positions when available. The intent is to provide a quick link offering assistance on Frequently Asked Questions reducing the need to search for tips. Note that many of these threads contain links to other threads releated to the topic.
CorvetteForum help FAQ tips, trics, and pics
Engine and Transmission FAQ (post 2)
C1 specific FAQ (post 3)
C2 specific FAQ (post 4)
Vendor FAQ (post 5)
Save the wave
Driver vs. Restored (common on CorvetteForum, NCRS to wild modifications)
Name your car?
Saftey Info:
Jack Stand Safety
Jack Stands Placement
Lift
Emergency Kit to cary
Adding Shoulder Belts (C2)
Safety Add-ons
Birdcage / Frame Rust:
Birdcage Rust
Birdcage Hints and Tips
Birdcage and frame rust
Frame rust
Frame rust
Cluster / Electrical:
Ampmeter accessability / removal
Battery Tender / charger
Battery / Alternator tests / charger
Battery disconnect
Cluster cleaning tips
Cluster removal (67)
Dash light short - extensive electrical checks
Gas gauge inaccuracy
Headlight aiming
Reasons to replace wiring
Should I replace my wire harness?
Speedometer / tach cable lube
Tuning radio to antenna
Wiring diagrams
Brakes / Steering:
Brake, Bleeding brakes
Brake, Drum to disk brake conversion
Brake, fluid, Silicon (DOT-5)
Brake, Fluid type
Brake, Convert single to dual master cylinder
Emergency brake adjustment
Power steering conversion
Steering gear lube
Body / Paint:
Body on frame paint
Cleaners and polish
Cleaners and polish (car care forum)
Chassis Suspension - cleaning and paint
Body Dolly
Paint, chip repair
Paint, chip repair
Paint, How much paint?
Paint, Make a paint booth
Paint, Painter questions
Paint, prep (gel-coat)
Paint, prep
Paint, tips
Paint, type
Paint, type
Paint, Strip
Scratch removal
Should I do a body off restore / cost
Stress crack repair
Matching Numbers:
Engine pad matching numbers
Original or Custom?
Trans and diff numbers
When was my car built?
Other:
Adding AC
Automatic trans (newer generation)
Average dollars spent
Dash restoration
Fix for enlarged screw holes
Front end shakes
Gear ratio (explanation)
Gear ratio, Determine your rear gear ratio
Headlight adjustment
Projects (easy)
RestoRod (newer frame sawp)
Steering Wheel Size
Tilt wheel conversion
Tires, High speed vibration
Tires, Nitrogen in tires
Tires, Radial tire alignment
Winter storage
Manuals you should have discussion
AIM (Assembly Manual)
Service Manual
Restoration Guide
NCRS(if doing NCRS restoration)
Books on glass, paint, restore
Note, this FAQ is a normal message thread. If you see a thread that is likely to be of interest to all, feel free to post a reply with the thread's link. Please do a quick look and verify it is not already posted first. Periodically the the thread will be maintained, certain post links may be moved to main and deleted, posts with no links may be removed, etc. The intent is for this thread to ba a place for truly Frequently Asked Questions. A 50 page FAQ is about as useful as a search that returns hundreds of results.
Old Nov 17, 2006 | 02:06 AM
bweaver999's Avatar
bweaver999
Default Engine and Transmission FAQ
Engine / Coolant:
Best all around Engine running temperture?
Interesting temperature problem
Over heating
Over heating
Water Pump / Fan
Carb / FI:
Fuel Percolation?
EFI (aftermarket)
EFI
Intake Install
Octane Discussion
Ignition:
Information On Timing
Is MyTiming Off
Distributor, Does My Distributor Need Re-Curved
Distributor, End Play
Distributor, re-build
Distributor, Points Install Question
Lar's Tuning Secrets
Ballast resistor
MSD ignition
Mallory Unilite ignition
Pertronix (points replacement)
Spark plug, Most popular spark plug for Corvettes
Spark plug, type
Lube:
Excess oil consumption
Oil Question
Oil, Synthetic oil
Posi rear lube
Transmission / clutch:
Convert Automatic to manual trans
5 speed clutch info
How much lube in a Muncie?
Muncie 4 speed grinding
Muncie 4 Speed Gear Lube
General:
Cam, recommendations
Cam, 3030 Cam
Clean aluminum intake / valve covers
Convert Small Block To Big Block
Decoding Engine Numbers
Engine rebuild tips
Fan Clutch
Helix coil
Max RPM discussion
New engine startup
Power vs. Torque
Re-Stamp numbers
PCV Discussion
PCV Valve Cover
Won't start
Chevy Torque Specs (non-Forum Site)
Old Nov 17, 2006 | 10:36 AM
bweaver999's Avatar
bweaver999
Default C1 specific FAQ
C1 specfic information:
3 speed to 4 conversion
5 speed
Body Off
Rear Spring
SRIII chasis (C4/C5 chasis)
Steering wheel "play"
Tire, Custom Wheels
Tire, Larger Wheels
Tire, choice
Tire, choice
Tire, choice
Tire, Size
Traction improvement
Old Nov 17, 2006 | 12:43 PM
bweaver999's Avatar
bweaver999
Default C2 specific FAQ
C2 specific information:
5 speed
5 speed
6 speed
Alignment
Alignment specs
Alignment specs radial tires
Alignment prices
Body off
Best non-stock improvements
Door hinge pillar
Dash Paint
Gas gauge check
Gran Sport Kits
Noise in Rear End
Rear wheel bearing check
Rear Wheel Woble
Offset Trailing Arm
Side pipe poll
Side Pipe Conversion
Side Pipe Conversion Kits
Side Pipe Discussion
SRIII chassis (C4/C5)
Suspension Upgrades
Tire, Size
Tire, Options
Tire, Performance Tires
Tire, Wheel Options
Water leak tips (windsheild)
Wheels, 17 Inch Rims
Wheels, Knock Off Wheels
Wheels, Knock Off Wheels Removal
Wheels, Knock Off vs Bolt On Wheels
Wheels, "New" Knock Off wheels
Wheels, Large Wheel
Wheels, Rally Wheel Size
Wheels, Rear Wheel Fit
Wheels, Torque Thrust
Wheels, Torque Thrust Wheels
Old Nov 18, 2006 | 08:37 PM
bweaver999's Avatar
bweaver999
Default Vendor FAQ
Which vendor do you like? Vote here.
The purpose of this FAQ thread is to provide a quick link to popular vendors. It contains links to sites outside of Corvette Forum.
Please do not add vendor comments positive or negative to the FAQ thread, use the Vote thread above or start a new on for that.
Posts in the FAQ thread should include a link to vendors not listed below.
General Corvette vendors listed alpahbetically:
Bair's Parts
Corvette Central
Corvette Forum Store (Zip)
Corvette Specialties Of Maryland
Corvette Stainless Steel Brakes
Dr Rebuild
Ecklers
Keen Parts
Long Island Corvette (C2 only)
The Last Detail
Mid America
Vette Brakes
Willcox Corvette
Zip Products
Specialty Corvette products / non-Corvette listed alpahbetically:
Al Knoch Interiors
Corvette Steering (Power Steering Conversion)
Corvette Stainless Steel Brakes, Power steering conversion
DeWitts Radiators
Dynamat
Engine Factory (Engines)
Gibbs Brand Penetrant Oil
5 Speeds (5 speed & Muncie 4 speed)
GM Parts Direct
JEGS
Keisler Engineering(5 speed)
Lectric Limited (Wiring Harness)
Wiring Ron Francis (connectors, etc)
SRIII C4/C5 chassis for C1/C2
Summit Racing
SpeedDirect (Steeriods)
Vintage Wheel Works
World Products (Engines)
Van Steel (Suspension, brakes, off-set trailing arms)
Vette Works (Fire Extinguishers, suspension and brakes
Re-build services:
Corvette Instrument Service
Eirc Freeman E-mail drvettejr@aol.com (no web site, Teak steering wheels)
Jason Oliver E-Mail VetteInstruments@aol.com (no web site, cluster re-builds)
Vintage Plates (thread has URL's)
John Pirkle Re-Build Electrical
Vintage Wonderbar Delco Radio Service
Joe's Classic Car Radio AM-FM
Other Corvette (non-Vendor sites of interest:
The Corvette Story
NCRS
The National Corvette Museum
Purchase Corvette Options / information:
Car purchase advice
Financing ideas
Ebay bid tips
NOM (Non Original Motor) price peduction
Old Nov 18, 2006 | 08:52 PM
bweaver999's Avatar
bweaver999
Text files of each post, a bit easier to correct in notepad than the forum editor
File Type: txt
File Type: txt
File Type: txt
File Type: txt
File Type: txt
To test
