test
First
Loosen the Axle nut.. Trust me.. this requires a lot of force. Leave the car on the ground with the wheel on when you break it loose.
So get some PB Blaster and spray the nut real good. I used a 24” ¾ Breaker bar from Harbor Freight. I needed to get some ¾ to ½ adapters to use my
socket.
Now you can see the havoc created by a torn boot..
I had to clean everything before I could do anything.. I went through a 6” stack of napkins, a dozen q-tips and an old t-shirt.
I even took the strain reliefs off the speed sensor wires and cleaned the grease out of them. Washed em in the sink with dawn and a tooth brush..
Here is everything all cleaned up..
Now we are ready to pull the axle.. Here is a shot just before pulling it out of the hub
Finally out..
Now to get the boot off.. My problem was with the OUTER boot..
First cut the clamps off both sides. I used a Dremel with cutoff wheel
Then slide back the boot in order to separate the CV joint from the axle shaft
To separate the 2 pieces you need to put the axle in a vise. Then take a heavy “BLUNT” Chisel and place it right at the point shown in the picture. You will need a give this some very hard whacks with a heavy hammer.. It will eventually slide off. What you are doing is compressing the snap ring on the inside. The next pictures will clearly show this..
If you look inside the bearing race.. you can see where it opens back up and the snap ring expands again on the other side to ensure a solid connection.
To be continued....
