test
List your year, mods, gearing, and transmission, or you will not be added to the list.
And if you 1/4 mile guys could put some 1/8th mi info up, the rest of us without full tracks would be very grateful.
You can also post your older best times with previous setups. My intent is that people can use this as a general reference on what to aim for with certain setups.
1/4 MILE, 12's and faster
ET MPH 60ft D.A. CAR MEMBER MODS
.9.82 @148 1.54 ...... 92 M6 3.73 97AGGIE... 383, 250shot direct port, custom cam, AFR 190s, 58mmTB, 36# inj, spec stg5 clutch, LTs, 3in exh
10.14 @137 1.43 ...... 95 M6 3.70 dr.juice.. 377ci, 9.5:1, 250shot, M&H slicks, AFR/TPIs heads, LT4 intake, LTs, 3" exh, Spec clutch, 4-link 9in, CCW drag pack
10.15 @134 1.37 ...... 89 A3 3.73 ski_dwn_it slicks, 434ci 11.5:1 cr, m2race system brodix t1 heads, Single plane, 3" exhaust, 8" race converter
10.44 @133 1.53 +4400' 91 M6 .... tpi421vett 421ci, ported miniram2, AFR220s, NOS, comp SR cam, F.A.S.T., monoblade
10.53 @131 .... ...... 96 M6 4.10 d48mclain. 398ci, stepped headers, ported TFS heads, monoblade TB, sheetmetal intake
10.83 @134 1.82 +1200' 90 M6 3.91 mos90..... 396 solid roller, slicks, 250shot, mcleod clutch, FAST xfi
10.90 @126 1.49 +2100' 86 A4 3.33 REDC4CORVE 434ci, MT streets, 1095 barry grant carb, LT4 exh,
10.97 @124 1.51 ...... 87 .. .... Pete K
11.01 @123 1.42 ...... 93 .. .... INSANITY.. 396
11.02 @126 1.60 ...... 96 M6 3.75 RichS..... DRs, 396ci, morgantini heads, ported LT4 heads/int, CompCam, DRM LTs, 58mm tb, 421hp/412tq
11.05 @123 1.60 ...... 90 .. .... SloRvette
11.21 @122 1.56 +2200' 94 A4 .... REDC4CORVE 125shot, 2600 TC, Comp cam, 1.5/1.6RRs, beehive springs
11.40 @120 1.58 ...... 86 A4 3.73 Gold1986Ve 420ci, 11.3:1, SR 248cam, ported Miniram, 3500 TC, AFRs, LTs, DRs, exhaust
11.61 @119 1.76 +1600' 93 .. .... steve40th. 425 rwhp 417 ft/lbs tq
11.71 @117 1.69 ...... 93 A4 4.09 93 ragtop. MT et DRs, 3000 TC, hotcam, ported heads, LTs, elec wp, pcmforless tune
11.77 @114 1.67 ...... 86 A4 3.07 jd_v3tt3.. 150shot, BFG DRs, LTs, elims
11.89 @120 1.9. ...... 96 A4 3.07 Dan Parker 75 shot, Nitto DRs, 3000 stall, LE2 heads/cam, EM LTs
11.94 @116 1.67 ...... 93 A4 4.10 BlackRoseL 2800 TC, stage2heads, hotcam, EM LTs, B&B exh, ported LT1, Alvin tune
12.13 @120 1.93 ...... 86 TKO ... ol,RJ..... 406ci solid roller, miniram, brodix heads, 246/.542cam, LTs, tune
12.19 @108 1.62 ...80F 86 A4 2.73 vetster86. Paxton SC 6psi, 2800 TC, SuperRam, LTs, 214/224 cam, 2.0/1.55 valves, 1.6RRs
12.19 @114 1.76 ...... 96 M6 4.10 jonecap... LT4, DRs, catback, tune
12.26 @115 1.80 ...... 93 A4 3.54 fredk..... 190 AFRs, ZZ9cam, EM LTs, claw intake, 1.6RRs, Autoworx tune
12.28 @110 1.65 .-460' 96 A4 3.73 Red96Coupe BFG DRs, 1.6RR, 160stat, Hypertech, 3500 TC, elims, skinny fronts and Weld Pro Star wheels
12.49 @108 1.63 ...... 91 A4 3.33 TA........ stock heads/cam, 2500 TC, LTs, accel intake, asm runners, 1.6RRs
12.50 @108 1.67 ...... 93 A4 3.45 Mr Mojo... 2800 TC
12.58 @114 2.17 ...... 85 M6 3.45 LD85...... 406ci, AFR 210s, Miniram
12.63 @111 2.01 ...... 96 A4 .... Legion21.. SLP cai, LTs, 3" exh, nitrous, mallory hyfire VI
12.65 @114 .... ...... 95 M6 .... gears..... hotcam, ported heads, ed wright chip, 52mmTB, tpis LTs, catback, vortex rammer
12.66 @108 1.83 ..100F 90 .. .... skateparkd M/T DRs, Hooker LTs, Monza muffs, Catless, 125shot, Jet Perf stg 2 chip, 160stat, Manual Fan Switch, Tossed frisbee
12.68 @108 1.86 ...... 89 A4 .... Chance.... 383(8.7:1), superram, port+polish TFS heads, transgo shift, true duals
12.89 @111 2.09 ...... 93 M6 4.09 DieL...... 1.6RRs, pullies, crane hi-6, accel u-groove plugs, Watson headers, no cats, K&N
12.89 @104 1.76 +1700' 92 A4 3.33 MTVette... 2600 TC, LTs, hotcam, 1.6RRs, RT cats, Xpipe, M/T DRs
12.90 @106 1.86 ....0' 92 A4 3.54 MTVette... 2600 TC, LTs, hotcam, 1.6RRs, RT cats, Xpipe
12.91 @110 2.09 ...... 96 M6 4.10 Dr. Evil.. hotcam, catback, K&N+cutlid
12.95 @108 .... ...... 84 .. .... elkabong.. rollerblock w/ Eagle internals, trickflow heads, 10.4:1, Comp XR269 cam, 1.6RRs, X-Ram, EM LTs, 7747 ECM
12.95 @108 1.99 ...... 89 M6 3.54 89sleeper. M/T streets, 383 GMPD short block, edelb heads, TPIs: 409 cam, Miniram, LTs, prom
12.98 @102 1.78 ...68F 87 A4 3.07 rodj...... M/T DRs, 2000 TC, ZZ4cam, SLPrunners, ported TPI, 58mmTB
12.99 @107 1.95 .-500' 95 M6 3.45 Mr Mojo... no muffs
12.99 @104 1.77 ...... 86 A4 3.07 jd_v3tt3.. BFG DRs, LTs, elims, stock iron heads
13.00 @106 1.93 ...... 89 M6 3.33 Razor89... nitto DRs, ZZ9 cam, ported heads, LTs, catback, bigmouth, LT runners, ported plenum, cai, 52mmTB, stageVchip
13.07 @108 2.07 -2150' 95 M6 3.45 Mr Mojo... stock
13.07 @105 1.96 ...... 92 A4 3.07 C4Crazy787 2800 TC, hotcam, 1.6RRs, EM LTs, 52mmTB, NP chip, K&N
13.07 @102 1.83 .-400' 88 A4 2.59 65Z01..... TC, SLP cai, 52mm TB, ported plenum, no precats, cat&back, 1.6RRs
13.10 @109 2.06 +500' 93 M6 3.45 mn_vette iron heads, no cats, mez, 58mmTB, 230/236 cam
13.11 @108 1.91 90 M6 jonecap DRs, TPIs intake+chip+runners, 1.6RRs, catback, no cats, pulleys
13.11 @107 1.90 87 A4 3.07 SpankYello 180cc intake heads, Edelbrock base, TPIS runners, ZZ4 cam, LTs
13.14 @106 1.97 89 M6 3.33 black_89_v 383, Superram, LTs
13.14 @103 1.91 89 M6 3.33 Z51L9889 ported 113s, no precats, cat&back, portedTPI
13.16 @105 1.84 -100' 94 A4 3.07 Red98C5 DRs, cai
13.17 @104 1.99 -400' 88 A4 2.59 65Z01 SLP cai, 52mmTB, ported plenum, no precats, cat&back, 1.6RRs
13.18 @103 1.79 +600' 93 A4 3.73 Fuzzy Dice Nitto DRs, LTs, 3200 TC
13.21 @103 2.03 +1100' 93 A4 3.45 James93LT1 hotcam, LT4heads, 1.6RRs, slp shorties
13.25 @111 2.6 96 A4 3.07 Dan Parker LE2 heads/cam, EM LTs
13.29 @108 2.21 -2150' 94 M6 3.92 DaveT just gears
13.32 @109 2.21 -2150' 95 M6 3.45 Mr Mojo stock
13.34 @ 99 1.82 85 black85 LTs, catback, pulleys, ported TPI
13.3. @106 2.0 87 M4 3.07 TUNED87vet 1000cfmTB, ported plenum, bigmouth base, AFRs, TPIS cam, LTs, cat+back, tune
13.37 @102 1.95 93 A4 Mr Mojo stock
13.38 @104 1.94 60F 95 A4 3.07 pettvette
13.4. @108 2.19 +1500' 90ZR1 4.10 cuisinartv 3" exhaust, Haibeck chip, meth injection
13.50 @101 1.99 -500' 88 65Z01
13.53 @104 2.15 +2500' 88 88espo 327ci solid roller, 461x heads
13.53 @103 95 M6 3.45 95_6spdvet
13.54 @107 2.24 +2445' 91 M6 neat 100shot, Hooker LTs, catback
13.60 @102 1.95 +2200' 94 A4 REDC4CORVE 2600 TC, Comp cam, 1.5/1.6RRs, beehive springs
13.62 @101 1.97 94 A4 3.07 LilRedCorv Borla muffs, K&N
13.6. @102 89 GIJoe no cats, TBswitch, no smog, hypertech, 160stat,
13.70 @104 2.05 +1000' 95 M6 3.45 SHINOBI-X B&M shifter, Xpipe, elims
13.75 @ 99 2.03 +2276' 89 A4 3.07 gigaglytch 2100stall, LTs, no cats, catback, K&N
13.78 @101 1.99 +600' 88 M4 3.07 88BlackZ51 Nitto DRs, Hooker LTs+Y, cat&back, K&N+lid
13.79 @100 2.00 +1000' 85 M6 3.45 CentralCoa M/T DRs, SLP cai, elims, cat&back,
13.8. @103 2.2 92 A4 3.45 MrNuke K&N, chip, Borlas
13.89 @ 99 1.97 90F 86 A4 JrRifleCoa MSD, catback, Alvin chip
13.90 @ 98 1.97 +600' 87 A4 3.07 87 rag 1.6rollertips, Borla catback, K&N
13.90 @ 99 2.0 90 M6 3.45 MATCHLIGHT catback, fan switch, 180stat
13.91 @102 2.24 +1500' 88 M4 3.07 88espo 327ci, 461 heads
13.91 @ 99 2.11 +2445' 91 M6 neat Hooker LTs, catback
13.93 @ 99 2.07 85 M4 3.07 rel3rd pulleys, hiflow cat
13.96 @ 99 2.01 +950' 89 M6 3.33 Z51L9889 stock
14.02 @105 2.30 96 M6 3.45 ALLT4 bone stock LT4
14.13 @ 98 1.99 85 A4 3.07 JohnMarker AFR 180s, SR, RRs, tjwong chip, MSD, transgo shift kit, cust exhaust
14.33 @ 97 2.13 86 Agent 86 no cats, no smog, magnaflow exhaust
14.46 @ 94 2.16 91 A4 2.59 1991 C4 B&B exhaust
14.47 @ 94 2.03 +2710' 89 A4 3.07 cuisinartv catback
14.63 @ 95 2.16 86 A4 3.07 KnightVett catback, K&N, (stock 86L heads)
14.7. @ 92 84 A4 3.07 xrcrx K&N, cai, RRs
[/code]
1/8 MILE
ET MPH 60ft D.A. CAR MEMBER MODS 6.45 @116 1.54 92 M6 3.73 97AGGIE 383, 250shot direct port, custom cam, AFR 190s, 58mmTB, 36# inj, spec stg5 clutch, LTs, 3in exh 6.64 @107 1.37 89 A3 3.73 ski_dwn_it M/T slicks, 434ci 11.5:1 compression, m2race system brodix t1 227cc heads, Single plane intake, 30# injectors, 3" exhaust, m/t front runners, turbo350 auto, 8" race converter 6.73 @104 1.51 91 M6 tpi421vett 421 bowtie block, ported miniram2, AFR220s, NOS, comp mech roller cam, F.A.S.T., monoblade 6.82 @103 96 M6 4.10 d48mclain 398ci, stepped headers, ported TFS heads, monoblade TB, sheetmetal intake 6.97 @ 97 1.51 87 Pete K 7.01 @108 1.82 +1200' 90 M6 3.91 mos90 396 solid roller, slicks, 250shot, mcleod clutch, FAST xfi 7.06 @ 98 1.60 90 SloRvette 7.10 @ 98 1.60 96 M6 3.75 RichS DRs, 396ci, morgantini heads, ported LT4 heads/int, CompCam, DRM LTs, 58mm tb, 421hp/412tq 7.24 @ 93 1.58 86 A4 3.73 Gold1986Ve 420ci, 11.3:1, SR 248cam, ported Miniram, 3500 TC, AFRs, LTs, DRs, exhaust 7.44 @ 93 1.76 +1600' 93 steve40th 425 rwhp 417 ft/lbs tq 7.52 @ 92 1.67 86 A4 3.07 jd_v3tt3 150shot, BFG DRs, LTs, elims 7.53 @ 92 1.69 93 A4 4.09 93 ragtop M/T et DRs, 3000 TC, hotcam, ported heads, LTs, elec wp, pcmforless tune 7.67 @ 88 1.67 93 A4 4.10 BlackRoseL 2800 TC, stage2heads, hotcam, EM LTs, B&B exh, ported LT1, Alvin tune 7.70 @ 87 1.62 80F 86 A4 2.73 vetster86 Paxton SC 6psi, 2800 TC, SuperRam, LTs, 214/224 cam, 2.0/1.55 valves, 1.6RRs 7.79 @ 88 1.65 -460' 96 A4 3.73 Red96Coupe BFG DRs, 1.6RR, 160stat, Hypertech, 3500 TC, elims, skinny fronts and Weld Pro Star wheels 7.85 @ 89 1.76 96 M6 4.10 jonecap DRs, catback, tune 7.88 @ 89 1.80 93 A4 3.54 fredk 190 AFRs, ZZ9cam, EM LTs, claw intake, 1.6RRs, Autoworx tune 7.92 @ 85 1.63 91 A4 3.33 TA stock heads/cam, 2500 TC, LTs, accel intake, asm runners, 1.6RRs 7.96 @ 91 1.93 86 TKO ol,RJ 406ci solid roller, miniram, brodix heads, 246/.542cam, LTs, tune 8.08 @ 86 1.83 100F 90 skateparkd M/T DRs, LTs, Monzas, Catless, 125shot, Jet stg 2 chip, 160stat, Fan Switch, frisbee 8.09 @ 90 1.87 0' 96 3.91 ericcer LT4 motor/hotcam, LT headers, catless, custom tune, elec wpump, delteq ign 8.10 @ 85 1.86 89 A4 Chance 383(8.7:1), superram, port+polish TFS heads, transgo shift, true duals 8.16 @ 84 1.78 85 A4 3.73 rssshen ve full roller 383, dart pro1 heads, CC 270HR cam, edelbrock base, 58mmTB, MSD 6AL, TPIs LTs, flows, 2600 TC, BFG DRs 8.17 @ 83 1.76 +1700' 92 A4 3.33 MTVette 2600 TC, LTs, hotcam, 1.6RRs, RT cats, Xpipe, M/T DRs 8.24 @ 84 1.86 0' 92 A4 3.54 MTVette 2600 TC, LTs, hotcam, 1.6RRs, RT cats, Xpipe 8.26 @ 82 1.77 86 A4 3.07 jd_v3tt3 BFG DRs, LTs, elims, stock iron heads 8.26 @ 83 1.78 68F 87 A4 3.07 rodj M/T DRs, 2000 TC, ZZ4cam, SLPrunners, ported TPI, 58mmTB 8.29 @ 87 1.90 96 M6 4.10 Dr. Evil hotcam, catback, K&N+cutlid 8.31 @ 91 2.04 107F 90 A4 3.45 conv90 383, trickflow heads, SuperRam, 219cam, LTs, 58mmTB 8.32 @ 86 1.90 87 A4 3.07 SpankYello 180cc intake heads, Edelbrock base, TPIS runners, ZZ4 cam, LTs 8.34 2.01 96 A4 Legion21 SLP cai, LTs, 3" exh, nitrous, mallory hyfire VI 8.35 @ 83 1.93 89 M6 3.33 Razor89 nitto DRs, ZZ9 cam, ported heads, LTs, catback, bigmouth, LT runners, ported plenum, cai, 52mmTB, stageVchip 8.39 @ 83 1.84 -100' 94 A4 3.07 Red98C5 DRs, cai 8.39 1.79 +600' 93 A4 3.73 Fuzzy Dice Nitto DRs, LTs, 3200 TC 8.40 @ 84 1.95 -500' 95 M6 3.45 Mr Mojo no mufflers 8.40 @ 86 1.99 89 M6 3.54 89sleeper M/T streets, 383 GMPD short block, edelb heads, TPIs: 409 cam, Miniram, LTs, prom 8.43 @ 84 1.96 92 A4 3.07 C4Crazy787 2800 TC, hotcam, 1.6RRs, EM LTs, 52mmTB, NP chip, K&N 8.43 @ 83 1.91 90 M6 jonecap TPIs intake+chip+runners, 1.6RRs, catback, no cats, pulleys 8.45 @ 83 1.91 89 M6 3.33 Z51L9889 ported 113s, no precats, cat&back, portedTPI 8.46 @ 81 1.82 85 black85 LTs, catback, pulleys, ported TPI 8.46 @ 85 1.97 89 M6 3.33 black_89_v 383, superram, LTs 8.48 @ 82 1.99 -400' 88 A4 2.59 65Z01 SLP cai, 52mmTB, ported plenum, no precats, cat&back, 1.6RRs 8.49 @ 83 2.07 -2150' 95 M6 3.45 Mr Mojo none 8.50 @ 83 2.03 +1100' 93 A4 3.45 James93LT1 hotcam, LT4heads, 1.6RRs, slp shorties 8.53 @ 88 2.17 85 M6 3.45 LD85 406ci, AFR 210s, Miniram 8.53 @ 86 1.97 60F 94 M6 3.45 chevy406 LTs, cai, no cats, centerforce DF, 1.6RRs 8.57 @ 85 2.06 +500' 93 M6 3.45 mn_vette iron heads, no cats, mez wp, 58mmTB, 230/236 cam 8.57 @ 84 1.94 60F 95 A4 3.07 pettvette 8.64 @ 79 1.86 -400' 85 M6 3.45 CentralCoa M/T DRs, SLP cai, elims, cat&back 8.65 @ 81 1.99 -500' 88 65Z01 8.71 @ 84 2.04 89 3.07 kopbet89c4 Superram, no cats/smog, Alvin chip, 24# inj 8.71 @ 82 2.21 -2150' 95 M6 3.45 Mr Mojo stock 8.73 @ 83 2.21 -2150' 94 M6 3.92 DaveT just gears 8.82 @ 78 1.97 +600' 87 A4 3.07 87 rag 1.6rollertips, Borla catback, K&N 8.84 @ 79 1.99 +600' 88 M4 3.07 88BlackZ51 Nitto DRs, Hooker LTs+Y, cat&back, K&N+lid 8.8. @ 81 2.2 92 A4 3.45 MrNuke K&N, chip, Borlas 8.83 @ 79 2.03 +2276' 89 A4 3.07 gigaglytch 2100stall, LTs, no cats, catback, K&N 8.84 @ 77 1.89 86 A4 2.59 Corv Chris K&N, muffs, (stock 86L heads) 8.91 @ 80 2.09 -200' 85 M6 3.07 CentralCoa SLP cai, elims, cat&back 8.91 @ 1.86 95 M6 3.45 95wht6spd cut lid + K&N 8.93 @ 83 2.24 +2445' 91 M6 neat 100shot, Hooker LTs, catback 8.95 @ 78 2.11 +2445' 91 M6 neat Hooker LTs, catback 8.96 @ 78 2.07 85 M4 3.07 rel3rd pulleys, hiflow cat 9.09 @ 78 2.06 +500' 85 M4 3.07 CentralCoa SLP cai, elims, cat&back 9.10 @ 82 2.24 +1500' 88 M4 3.07 88espo 327ci, 461 heads 9.23 @ 76 2.13 86 Agent 86 no cat, no smog, magnaflow exhaust 9.24 @ 74 2.03 +2710' 89 A4 3.07 cuisinartv catback 9.32 @ 76 2.16 91 A4 2.59 1991 C4 B&B exhaust
CAI: cold air intake
DRs: drag radials
elims: muffler eliminators
LTs: long tube headers
RRs: roller rockers
TC: torque converter
