test
Old Mar 15, 2007 | 10:33 PM
turboc5's Avatar
turboc5
Default test
[IMG][/IMG]
Old Mar 15, 2007 | 10:34 PM
turboc5's Avatar
turboc5
[IMG][/IMG]
Old Mar 15, 2007 | 11:34 PM
turboc5's Avatar
turboc5
Driveline
$1,100.00 Textralia OZ700SB clutch with lightened steel flywheel
300.00 ZO6 master cylinder, slave cylinder, and drill mod
500.00 LWA strengthened drive shaft couplers with reinforcement backing
280.00 Lingenfelter hardened out put shaft for diff.
+260.00 Hurst Billet Pro shifter
$ 2440.00
Engine
$380.00 ASA Camshaft from GMPP
160.00 Ported and shimmed (10 more psi) ls6 oil pump
30.00 Heavy duty timing chain from GMPP
250.00 Heavy duty valve springs from GMPP
1600.00 LG PRO Long Tube headers (off road version, cats can be slipped on)
50.00 Taylor 10.9 plug wires with NGK TR55’s
50.00 K&N panel filter
+500.00 HP Tuners system for 2000 and 99 C5’s
$ 3320.00
Chassis
$ 180.00 Elite ceramic coated ¼” aluminum tunnel plate
300.00 Bilstien sport shocks (valved for lowered Z51 cars)
20.00 Lowering bolt kit
850.00 T1 Sway bar kit with adjustable rear sway bar.
610.00 Bear Brake +1 kit with composite rotors
Brembo front rotors and hawk pads all around
800.00 1 ½” Rear Mini Tub (Clearance for a 345 Tire!)
2000.00 CCW Classics with a black anodized, lightened and shot peaned center
1700.00 Michelin PS2’s with a 295/30-18 F and a 315/30-18 R
+ 2500.00 4130 1 5/8” by 0.83 wall Chrome molly Roll cage (weighs 60 lbs, Light!)
$ 8860.00
Other
$ 1800.00 + Paint MCM Dry Carbon fiber hood with the clear carbon center panel
Shaved hood and trunk emblems
200.00 Custom C5R style Hella driving lamps with Raybrig bulbs
Custom blacked out front signal lenses.
200.00 Light window tint (done by the same people that do Michel Jordan’s cars)
150.00 Trunk divider (keeps out exhaust drone and separates trunk from cabin,)
+1500.00 Sparco Alcantera seats.
$ 3850.00
8860.00
3320.00
+2440.00
$18,470.00
Old Mar 15, 2007 | 11:46 PM
turboc5's Avatar
turboc5
[IMG][/IMG]
Old Mar 15, 2007 | 11:52 PM
turboc5's Avatar
turboc5
[IMG][/IMG]
To test
