Idle Re-Learn
Old Apr 26, 2007 | 08:28 PM
Glennm27's Avatar
Glennm27
2017 C7 of the Year Finalist
St. Jude Contributor
Default Idle Re-Learn
Automatic Transmission
Perform the following procedure in order to return the learned idle to the correct position:
  • Turn OFF the ignition.
  • Restore the PCM battery feed.
  • Turn OFF the A/C controls.
  • Set the parking brake, and block the drive wheels.
  • Start the engine.
  • Ensure that the engine coolant temperature is more than 80°C (176°F).
  • Shift the transmission into Drive.
  • Allow the engine to idle for 5 minutes.
  • Shift the transmission into Park.
  • Turn OFF the engine for 30 seconds.
Manual Transmission
  • Place the transmission in Neutral.
  • Start the engine.
