If you're trying to embed images inside posts from your Photobucket account, all you'll need to do is copy/paste the IMG code that's found on each of your photos.
Click on one of the images you want to embed inside a post. To the right there is an IMG Code section followed by some coding. If you simply click on that, you'll see a "Copied" message appear. The code is now copied to your clipboard. Simply return to your post here on CorvetteForum, and then right-click and Paste the code inside the message box.
