test
Old Aug 22, 2012 | 09:59 AM
savewave's Avatar
savewave
CI 2-3-4-5-6-7-8-9-10-11-12
Wounded Warrior Escort '11
NCM Lifetime Member
Default test
First locate the strap screw and loosen it per (arrowed). Next, remove only the outer two screws on the air filter assembly but REMEMBER which side goes to which... the screws are NOT the same length. Once these two screws are removed, the entire assembly pulls up and out. The next photo shows the radiator air deflector. The red arrow indicates where I “think” the tongue should be pulled up through. The blue arrow indicates where I am not sure if the wing should be folded up over the hinge or down under the hinge.
