test
Old Jun 4, 2013 | 11:02 AM
ATLZ06's Avatar
ATLZ06
Default test
Test
Old Jun 4, 2013 | 11:10 AM
ATLZ06's Avatar
ATLZ06
2nd Test of Sig.
Old Jun 4, 2013 | 11:13 AM
ATLZ06's Avatar
ATLZ06
test 3
Old Jun 5, 2013 | 02:26 PM
ATLZ06's Avatar
ATLZ06
This is the solution IF YOU DO NOT SEE YOUR SIGNATURE!!!
Thank You
From Moderator:
You may have created a signature but it's not appearing when you post. In order for your signature to be visible, you must turn that feature on. By default this is set to "unchecked" or "off" to speed up the loading of web pages and provide a cleaner viewing experience.
If you would like to turn on the ability to view signatures (after you've created one) you must go to the user control panel and select "Edit options," a direct link is here: http://forums.corvetteforum.com/prof...do=editoptions. From here you will need to find a box entitled "Visible Post Elements." The first checkbox is "Show Signatures," ensure this is checked. Finally, scroll all the way to the bottom and SAVE CHANGES. You will now be able to see your signature.
Old Jun 5, 2013 | 10:25 PM
Alex1217's Avatar
Alex1217
St. Jude Donor '08-'09
Test reply
To test
