1980
93K- Miles, note-the car is a Canadian car so the odometer is in kilometers!
Car is located in Shorewood IL, 60404
Clean Title in hand.
Have owned this car for the past 20 years, recently upgraded to a C8
Stored in winters
Runs well and shifts smoothly.
Everything works except the clock, antenna motor, A/C.
Smog pump and A/C pump were removed
Heater core bypassed (this is my summer car)
All major mechanical work was completed by local specialty corvette shop
Alpine Stereo, Focal speakers, shallow subwoofer, Cadence Amplifiers
Corvette Astro top one piece targa top
Known Issues:
- Passenger side external door latch at times sticks, can be opened from inside with no issues, passenger window down switch at times doesn’t work (have a new switch on hand)
Replaced:
- New tires 2023
- Front seats upgraded to C5 Z06 seats
- Interior Carpet
- Rear cabin panel doors
- High Flow Water Pump
- High Flow Thermostat
- 4-Row Radiator
- Coolant hoses
- Engine belts
- Distributor
- Alternator/Battery
- Brake calipers/rotors/pads
- Front suspension rebuilt
- Shocks front and rear
- Rear leaf spring and half shaft u-joints
- Rear trailing arms
- Corvette double hump Fuelie heads 041/186 2.02 1.60
-$14,500
