Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
Michelin PS2 question
Old May 2, 2005 | 09:28 PM
elh0102's Avatar
elh0102
Default Michelin PS2 question
I recently put PS2s on my C6. I've done two track schools on them, and they are the best tires I have ever used! During the two track events, I was running the tires at 36 to 38 psi most of the time, on track. Then today, I was doing a little spirited driving around a couple of my favorite highway ramps, and the tires seemed to handle even better, and the pressure was about 30. So now I'm wondering if I have been running them a little over-inflated on the track. I'm sure going to do a little more experimenting next time on the track. Just wondering what pressure others using the PS2 have found to be the best?
Old May 23, 2005 | 08:01 PM
Greg00Coupe's Avatar
Greg00Coupe
Only down side I've experienced is disappointing wet traction.
Old May 24, 2005 | 08:30 PM
landho's Avatar
landho
people usually run at higher pressures on the track for 2 reasons. to prevent the tire from rolling under in a turn and to keep the tire temp in a certain range. Call or email michelin to get their recommendation on cold AND hot psi...I think 36-40 would be the range...probably higher in front than rear...I would talk to michelin....
To Michelin PS2 question
