Hunter Road Force Balancing
I just replaced the front tires on my ZR1 with 2 Sumitomo's (275-40R17). They both balanced with 1/2 ounce of weights or less but the road force number was 15 lbs for one and 19 lbs for the other. The shop people seemed a bit vague on what exactly it meant and said that big tires such as these might be out this much and be considered OK. They said a touring tire on a Taurus or a Caddy might be expected to be within 10 lbs.
Can anyone comment on this?
Thanks,
Doug Gifford
When I had my run-flats switched over to my CCW wheels 3 years ago, I had them done on a Hunter balancer, but I don't remember the exact roadforce numbers. I doubt, however, that it was as high as your Sumitomos. I replaced the tires on my wife's Jaguar last year with Firestone Firehawks (225/60-16). IIRC, the roadforce numbers were in the 9-12 lb. range.
