Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
Alignment Question..........
Old Oct 4, 2005 | 03:43 AM
AMGPilot's Avatar
AMGPilot
Default Alignment Question..........
Wednesday I am having new tires and wheels installed on my 2004 C5 Coupe and I have a couple of alignment related questions for you guys.
I am installing C6 Z06 reproducton wheels 18x9.5 57mm offset (front) and 19x11 64mm offset (rear) with Michelin Ps2's 275/35ZR18 (front) and 305/30ZR19 (rear).
I have the F55 suspension with the car slightly lowered with Z06 sway bars installed.
I do not race the car, it is a daily driver and I am looking for the best ride and tire wear.
My questions are:
1) Would the stock alignment specifications be the best for my car with the information I supplied above or should I adjust the specifications any?
2) Are these the correct stock alignment specs for my 2004 C5 Coupe?
