Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
Technical question, need help
Old Feb 6, 2006 | 11:17 AM
MTurnbo's Avatar
MTurnbo
Default Technical question, need help
I bought a used set of HRE Mallett wheels ( 3 piece) and one of the fronts has a leak. I finally found it, "them" actually. There are three bolts on the inside of the rim that are leaking air. Two have washers under them making me think they've leaked before. I've found some bolts to replace the ones that are there and am going to try some nylon washers to help seal. I'll probably also wrap the threads with teflon tape. Now the question. Any idea what these bolts would torque at? They are M8X1.25X25. Also appreciate any advise on how to get them to seal.
Thanks, Mickey
Old Feb 6, 2006 | 03:20 PM
Luke@tirerack's Avatar
0Luke@tirerack
Former Vendor
St. Jude Donor '11-'12
DO NOT ATTEMPT THIS REPAIR YOURSELF !!! Contact a wheel repair shop .... one of the best in the country is
WHEEL TECHNIQUES
3280 D EDWARDS AVE
SANTA CLARA CA 95054
408-496-6363
or contact HRE
