Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
Simple Rim size question
Old May 11, 2006 | 02:35 PM
TBone68's Avatar
TBone68
Default Simple Rim size question
I have a 93 vert with brand new Firestone Wide Ovals on it and was looking at adding some new rims around the fall of this year. I did not change the normal tire size 255/45/17 fronts and 285/40/17 on the rear. Here is my question: Looking at the Z06 motorsports, do I need 17 x 8.5 all the way around or 8.5 on the front and 9.5 on the rear?
Thanks.
Old May 12, 2006 | 10:16 PM
MYCoupe's Avatar
MYCoupe
You can go either way 17x8.5" up front and 17x9.5" in the back or 17x9.5" all around. Personally I would go with the 17x9.5" all around. This way you have two options, upgrade to 275/40/17 tires up front at a later date or do the 275 or 285 tires all around.
Old May 14, 2006 | 11:43 AM
TBone68's Avatar
TBone68
Thanks very much for the help. I think 9.5 all around sounds good.
Tbone
To Simple Rim size question
