Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
Custom Offset Help.
Old Jul 20, 2006 | 06:52 AM
Midnight Storm's Avatar
Midnight Storm
Default Custom Offset Help.
Alright, I need some help getting the corret offsets for my car. This is what I got.
6 inch wide body kit front and 2 inch wide in the rear.
Thats 3 inches per side front and one inch per side rear.
The rear fender is pulled out so I'm thinking stock rims to inch wider rear.
I want deep dish wheels in the rear as well. 19 by 10 - 12 inches wide.
The fronts I want 18 or 19s by 9-10 inches wide.
I believe this would be the correct set up but correct me if I'm wrong.
What Offsets do I need to be looking for?
Thanks!!!
~MS
Old Aug 1, 2006 | 10:14 PM
ajg1915's Avatar
ajg1915
St. Jude Donor '08
I had a set of rims made for me by CCW (John & Chip).
I am in the process of getting a custom body kit from ACP. John at CCW recommended that I go with a Viper set-up. (F) 19 x 11 (305's) and the (R) 20 x 12.5 (335's) Michelin PS2.
Tell John about your kit and he will make offset to push wheel out by making a thicker center hub section.
