can anyone tell me the offset on stock C4's ...17x8.5 ft. and 17x9.5 rears. also anyone purchase wheels from OE Distributors in Sarasota fl. ? fit and finish ?
Is there any particular reason to go with 17 x 9.5" wheels all the way around? Just curious.
It would allow you to rotate your wheels from front to rear.
You will probably get a little better wear out of your tires. At least I
did on my '91' and '94'.
That is one reason. The other is that it allows you to use wider tires up front, which will reduce understeer.
