Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
Can someone answer this?
Old Oct 20, 2006 | 01:06 PM
kylryn's Avatar
kylryn
Default Can someone answer this?
Will Stock Z06 Wheels fit a normal C5? is there an offset issue? I know the wheels are a little wider but do you need spacers if you were to use stock Z's on a reg c5?
Old Oct 20, 2006 | 02:14 PM
Luke@tirerack's Avatar
0Luke@tirerack
Former Vendor
St. Jude Donor '11-'12
I have seen it done many times
Old Oct 20, 2006 | 02:16 PM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
No issue at all, people can even run 18x11 w/o issue.
You are good to buy a set.
Now, if you are talking about C6 Z06, then you will have issue.
Good luck!!!
-Mike
To Can someone answer this?
