Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
Wheel size ?
Old May 3, 2007 | 10:23 PM
jor8888's Avatar
jor8888
Default Wheel size ?
17x8.5 and 18x9.5 or 17x9.5 and 18x10.5 for 275 and 295 setup? or both work? thx.
Old May 4, 2007 | 01:50 AM
ICaughtVetteFever's Avatar
ICaughtVetteFever
Both should work, but the larger ones would be best.
Old May 4, 2007 | 12:40 PM
Darion's Avatar
Darion
The second setup would be more ideal.
Darion
Old May 16, 2007 | 09:24 PM
swifturn's Avatar
swifturn
3rd Gear
Although both may work, I'll use the first set-up if I were you.
_______________
Spencer
Northern Auto Parts - Northern Auto Parts Issue 82
Old May 17, 2007 | 08:43 AM
Luke@tirerack's Avatar
0Luke@tirerack
Former Vendor
St. Jude Donor '11-'12
while both would work it really depends on what you are looking to achieve. Personally, I would opt for the better handling the 17x9.5 and 18x10.5 with 275 and 295 setup would give you
Old Jun 16, 2007 | 03:48 PM
R Mackow's Avatar
R Mackow
The stock C5 sizes will work. I run a kumho V710 in 275 front. i also have a BFG KD in 295 rear. They are a challenge to get on.
To Wheel size ?
