Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
tire expert needed.
Old Jun 25, 2007 | 09:54 PM
the blur's Avatar
the blur
Default tire expert needed.
My truck developed a shimmy in the steering wheel at 40 mph. very pronounced. Found a 1" drywall screw in the front tire. nothing big, just a standard drywall screw. went to tire shop, patched tire from inside, and I watched him balance it perfectly.
drive truck, same shimmy at 40 mph !!
went back to tire shop, rebalance all 4 tires, all balance perfect. 0/0 on re-check.
still same shimmy at 40mph, and this is after I watch them balance all 4 tires perfectly. so now I have 4 balanced tires with a nasty shimmy.
So I decide to rotate repaired tire to the rear, SHIMMY GONE !!
So the cause of the shimmy was the tire with the drywall screw that got repaired properly.
so my guess is the 1" dry wall screw cut a steel belt inside the tire. (even though it balanced ok)
and it caused a shimmy. is this possible?
what else could have happened ?????
I'm still running the tire, but it is on the rear, where I can't feel it.
Old Jun 26, 2007 | 09:50 AM
WELEPRO's Avatar
WELEPRO
It's possible that the puncture damaged the structure of the tire. This is noticable when the tire is on the balancer, but the tech would have to be looking for it. Most standard balancers won't pick up an out of round tire, they just measure the inbalance.
Some higher end balancers, such as road force balancers and such WILL detect those problems, but not many tire dealers use them(although I think they should).
Anyhow, what kind of tire is it that's giving you problems? Any idea of the age? Most manufactures will waranty against those problems.
Old Jun 26, 2007 | 05:29 PM
Luke@tirerack's Avatar
0Luke@tirerack
Former Vendor
St. Jude Donor '11-'12
a road force variation balancer would be able to determine what the problem is, if it is wheel/tire related. If the tire was run low it could have internal damage which could be the root cause of your vibration
Old Jun 27, 2007 | 06:34 AM
the blur's Avatar
the blur
The tire was never ran low, maybe 5 lbs low if anything at all.
Now I'm wondering if it is safe to run on ?
To tire expert needed.
