Tirerack tread depth article
I really believe them on this one. I don't let my wife's or my car ever get below 4/32.
I did a 360 at 70mph one time in my Camaro due to low tread depth on a just rained on highway. I wasn't braking or turning when the spin occurred either.
http://www.tirerack.com/tires/tests/...y.jsp?ttid=85&
NASA (among others) has done a wealth of research, and it doesn't matter how deep your tread is, if you are driving to fast. Anything more than 57 mph in your Corvette, and you are asking for trouble.
Here's why:
http://howthingswork.virginia.edu/page1.php?QNum=1342
"...a NASA study showing that there is a minimum speed at which a tire will begin to hydroplane and that that speed depends on the square root of the tire pressure. Higher tire pressure tends to expel the water layer and prevent hydroplaning, while lower tire pressure allows the water layer to remain in place when the vehicle is traveling fast enough.. a large truck tire is typically inflated to 100 PSI and resists hydroplaning at speed of up to about 100 mph. But a passenger car tire has a much lower pressure of about 32 PSI and can hydroplane at speeds somewhat under 60 mph. That's why you have to be careful driving on waterlogged pavement at highway speeds and why highway builders carefully slope their surfaces to shed rain water quickly."
Two more links, one with a table to make the math easier:
http://oea.larc.nasa.gov/PAIS/Groove.html
and
http://www.mountainflying.com/hydroplane.htm
