Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
C3 offset trailing arm install
Old Jun 19, 2008 | 02:10 AM
redson's Avatar
redson
Default C3 offset trailing arm install
I am currently running 245/45/17's on my 79 Vette.If I install Van Steel offset trailing arms in back,what size 17's will fit,& look right? I dont think theres anything wider than 255's in 45/17's.
Old Jun 20, 2008 | 05:04 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
It all depends on if you have a rear sway bar, are willing to shorten your springs or have a dual mount spring. If you don't run a rear bar, and are willing to shorten the spring a 1/2 " on each side, you can use a 17x10 w.a 5.5" backspace and run a 285 series tire.
Old Jun 20, 2008 | 06:25 PM
redson's Avatar
redson
Thanks. I have installed front & rear dual mount composite springs.lowered about 1.5" all around. I only have a front bar now
Old Jun 22, 2008 | 02:13 PM
Van Steel's Avatar
Van Steel
285/45/17 10" wheel 5.5" backspacing.
To C3 offset trailing arm install
