For 285 or 275 front or rear you need 17 x 9.5 x 56, with 56 being the off-set.
For 315's on rear you would need 17 x 11 x 50, with 50 being the proper off-set....(which is the "GrandSport" off-set) :)
Did you even read my question?
I got it figured out now. It will stick out 3/8ths of an inch past where the stock rims are. Most of that should fit under the fender so I think it should look killer! Pics coming soon.
