Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
Do Radials Have A "Memory"?
Old Jan 17, 2002 | 05:44 PM
rubyred93's Avatar
rubyred93
Default Do Radials Have A "Memory"?
I'm sure that this is just as debatable as anything else, but I have received conflicting opinions over allowing steel-belted radials to sit for 4 to 6 months at a time.
I think we all can agree that when a tire sits for an extended period of time, it is likely to develop a "flat spot". The question is this: does that "flat spot" permanently damage the tire (as in the tire has a "memory" because of the steel belts, and it will no longer be exactly the same) or...once you drive on the tires for a distance the flat spots even out, and the tire has not been altered in a detrimental way.
I know many guys put their cars up on jack stands for Winter storage, but some do not.
What do you guys think about this? :confused:
Old Jan 18, 2002 | 12:07 PM
SWCDuke's Avatar
SWCDuke
Default Re: Do Radials Have A "Memory"? (rubyred93)
Tires, particularly speed rated types with nylon belts, will flat spot - even overnight, but they round out again when warmed up from driving although it's possible for them do develop a permanent out of round from extended stroage.
If the car is placed on jackstands the bushings are strained in torsion and can be damaged. That's why the AIM and service manual state to tighten the bushing bolts with the car at normal ride height.
Since it's easier/cheaper to change tires than suspension bushings I do not recommend storing cars on jackstands. Store them on the ground and inflate the tires to at least 35psi or the maximum cold pressure listed on the sidewall placard.
Duke
Old Jan 18, 2002 | 01:24 PM
grumpy55's Avatar
grumpy55
Default Re: Do Radials Have A "Memory"? (SWCDuke)
You could also store the car with the wheels in those contoured wheel dollies.
Old Jan 21, 2002 | 08:44 PM
GlockLT4's Avatar
GlockLT4
BFG G-force KD TA's will flat spot within hours... the rubber is sooo soft.
Old Jan 23, 2002 | 03:17 PM
USAZR1's Avatar
USAZR1
Default Re: Do Radials Have A "Memory"? (Glock'94)
My Michelins do it,too. They smooth out after 5-10 miles of driving,though.
To Do Radials Have A "Memory"?
