bought wrong size tires
I posted this on the C5 forums maybe someone here can get me in the right direction.
I recently bought four 06 z06 wheels for my car. They are18 x 10.5 rear and 9.5 x 17 front.
I also bought Falken 265/40/17 for the front which fit great and 285/35/18 for the rear. Which is where I am having the problem. The tire that is called for is a 295/35/18 but Falken dosen't make them so the guy I bought them from(tires direct) said the 285's will work. I mounted the 285's on the rear wheels and when I put them on the car they didn't look right. The tire looked to small for the width of the rim.
So now the problem is do I buy 4 tires so I have a matched set. Buy the right size in another brand just for the rear, 2 different thread styles. Or the should I buy a set of 9.5 x 18 wheels for the back and mount the 285's on them. The back spacing on the 9.5 x 18's are 54 mm.
Pictures???
I have a hard time believing that the difference between a 285 and a 295 would be that noticable? I'd be very curious to see pictures if you have any as I am currently contemplating buying 285's for my 18x10.5's as well.
