Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
offset question
Old Dec 9, 2009 | 01:08 PM
blakngold4life's Avatar
blakngold4life
Default offset question
I'm starting to look for new wheels for my 86, which I have gs fender flares I plan on putting on. To have the wheels sit out further to match the flares should I look for something with a lower offset or am I misunderstanding something. Also, how much can I deviate from the factory bolt pattern or does that have to be exactly the same as stock?
Old Dec 9, 2009 | 10:44 PM
fat bob's Avatar
fat bob
blakngold4life,
positive offset moves the wheels inboard as the number gets higher.
If your stock offset is +65 and you install wheels with a positive offset of +40 that will move your wheels outboard approximately 1 inch and more or less depending on what size tire you install will influence the net result.
Bob
