Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
offset measures from?
Old Mar 26, 2002 | 11:49 PM
rbiron0716's Avatar
rbiron0716
Default offset measures from?
when a wheel measurement refers to an offset number say 4 3/4 or 5"...does the higher number move the rim away from the inside of the car or closer to it?
Old Mar 27, 2002 | 09:46 AM
racewheel's Avatar
0racewheel
Former Vendor
Default Re: offset measures from? (rbiron0716)
offset is the distance from the hub face to the centerline of the wheel
backspacing is the distance from the hub face to the inside edge of the wheel
backspacing is easy to measure, offset has to be calculated
outside edge to outside edge measurement will usually be 1" larger than the bead to bead width (which is what rim width refers to) so a 10" wide wheel will typically measure 11" from outside edge to outside edge so the centerline (0 offset) will be 5.5" from the inner edge of the wheel
Old Mar 27, 2002 | 09:02 PM
carter200's Avatar
carter200
Default Re: offset measures from? (racewheel)
Listen to Racewheel as he is the man when it comes to wheels :yesnod: :seeya
[Modified by carter200, 7:02 PM 3/27/2002]
To offset measures from?
