Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
wheel width input
Old Apr 10, 2002 | 09:57 PM
dennis's Avatar
dennis
Default wheel width input
Anyone running 16x10's on an early 70's?
Old Apr 11, 2002 | 12:57 AM
Bronco Rider's Avatar
Bronco Rider
Default Re: wheel width input (dennis)
I am running 17 x 9.5" wheels with a 4.5" back set and 275/40/17 Kumo tires on an 81. No midifications necessary. Bolt on and run.
17" wheels look great on a c-3.
Old Apr 11, 2002 | 08:46 PM
TA's Avatar
TA
Default Re: wheel width input (Bronco Rider)
Bronco, you got any pics...........its sounds like a cool set up :cool:
Old Apr 11, 2002 | 09:39 PM
dennis's Avatar
dennis
bronco rider
just about no offset. No rub?
Old May 1, 2002 | 11:57 PM
Bronco Rider
Dennis,
The critical piece is the 9.5" width and the 4.5" back set and the 17" diameter. They do not rub and I have lowered the car and run it auto cross.
If you were to run a taller tire than the 275-40-17, it could rub.
I am also running 1.7 degrees negative camber.
There is a chance you could run a 16-10 with a 4.75" back set but you would need to bolt them up and check for potential problems.
Good luck,
Bronco rider
Old May 2, 2002 | 12:32 AM
Voltech_LT4's Avatar
Voltech_LT4
Cruise-In IV Veteran
yes, i heard that 285's rub a little.
vr,
Volt
To wheel width input
