Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
Continental ExtremeContac DWS
Old Apr 4, 2012 | 08:22 PM
PR1AWRet's Avatar
PR1AWRet
Default Continental ExtremeContac DWS
Had a set installed today and an alignment. Camber was at 22 degrees.
Had Goodyear GD-D3.
10 mile drive home was....quiet. Pushed it a bit on a banked on ramp and seem to be as good as the F1's but haven't really pushed them.
Got 275/40-17 front and 295/35-18 for the back.
Old Apr 7, 2012 | 07:16 AM
heli-vette's Avatar
heli-vette
Default Just got two rears
Looks good , I just recieved Two rears from UPS for my C6 I need to mount . They will replace the run flats / fire hawks . Sounds like the ride should be better Than the RFs .
I really need to find taller front tires or kick up the sprung height a smidge . Even with angle shots at the speed bumps and driveways dead slow . This rig is an ant eater , I can deal with less down force and a hot running engine .
Old Apr 7, 2012 | 11:21 AM
dogboy's Avatar
dogboy
I have the DW only on my rears in 295/30-18" & so far they seem to be the best street tires I ever had. I had nitto's, GYSC, Toyo proxies & none compare. I was able to pull 1.8's 60's on a prepped track for drag racing & they seem to take hold well on 100 mph + road surfaces when making curves. Also a great weight reduction advantage over other tires in those sizes. I'll get a set for the fronts when the Falken 451's wear out.
You driving in the snow?
Old Apr 7, 2012 | 05:14 PM
PR1AWRet's Avatar
PR1AWRet
Its a DD so a lot of miles will get racked up. The DW are 30K warrantied and the DWS are 50K. IIRC the DW's are cheaper though.
Old Apr 20, 2012 | 04:14 PM
Trash's Avatar
Trash
How many miles did you have on the F1s? How much quieter were the DWS at highway speeds?
I'm looking into getting the DW or PS2 in the future.
Old Apr 23, 2012 | 01:05 PM
PR1AWRet's Avatar
PR1AWRet
On the Goodyear GD-D3 I got 29K out of them but that was due to the -22 degrees (front) on camber. A good bit out of spec. If the alignment wasn't hosed could have gotten about another 2-3K on them.
The DWS are really quiet. Really really quiet. See how they fair through the life cycle though.Took it out for some canyon carving yesterday and happy with the performance. Just a fraction worse than the Goodyear GD-D3 for dry traction. If the GY were 10 then these would be 9.5.
If you are going sticky tires, although I haven't run them, I'd go with the PS2.
Old Apr 23, 2012 | 01:36 PM
Trash's Avatar
Trash
Thanks for the feedback. I'd like to get the PS2 but have some other items that need attention ($) first so I may opt for the DW.
To Continental ExtremeContac DWS
