Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
Tire Size?????
Old Jun 29, 2002 | 11:15 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Default Tire Size?????
Currently running stock run flats on my 2001 coupe. F245/45-17, R275/40-18. I just ordered the Goodyear supercar tires in the stock ZO6 sizes. F265/40-17, R295/35-18. Can someone tell me the difference in the height of these tires? Are they taller or shorter and by how much? :confused: On the bright side I do know the ZO6 tires are wider. :lol:
Bob
Old Jun 29, 2002 | 11:33 PM
MySea6's Avatar
MySea6
Default Re: Tire Size????? (16Again)
Hope you are changing the wheels as well...
You can get the sizing info on the Tire Rack site :cheers:
http://www.tirerack.com/tires/goodyear/goodyear.htm
[Modified by MySea5, 9:36 PM 6/29/2002]
Old Jun 30, 2002 | 07:23 AM
16Again's Avatar
16Again
Default Re: Tire Size????? (MySea5)
No the wheels are remaining, the new tire is 1" wider and will work on the stock rims. What I need to know is the ZO6 taller or shorter? and how much? I know nothing about tire sizing and for the life of me can't fiqure out what tire rack's site is telling me. :confused:
Bob
Old Jul 1, 2002 | 02:55 PM
MySea6's Avatar
MySea6
The reason I ask about the wheels is because, by your sig, it looks like you have the stock 5-spoke C5 wheels (17x8.5 and 18x9.5) which are really too narrow for the Goodyear supercar tires (Z06). Although you might get someone to stretch them on there for you, I would not do it. The stock Z06 wheels are 17x9.5 and 18x10.5, a full inch wider.
Anyway here are the specs from the Tire Rack site::
Stock front runflats
245/45YR17 Recomended Rim width of 7-9.5", section width is 9.6", tread width is 9.2" and overall diam. is 25.6"
Front F1 Supercar
265/40ZR17 Recomended Rim width of 9-10"", section width is 10.7", tread width is 9.6" and overall diam. is 25.4"
Stock rear runflats
275/40YR18 Recomended Rim width of 9-11", section width is 10.8", tread width is 10.3" and overall diam. is 26.7"
Rear F1 Supercar
295/35YR18 Recomended Rim width of 10-11.5"", section width is 11.7", tread width is 10.2" and overall diam. is 26.1"
The Z tires are a bit shorter, not a big deal. I would be much more concerned with cramming those tires on your narrow wheels. You might read where guys get away with it but I would not do it.
:cheers:
Old Jul 1, 2002 | 05:12 PM
16Again's Avatar
16Again
Thanks for the info. Goes to the shop Wed. Those who have done it seem to think the car handles very well. Anyway, until I save up enough for the rims this will have to do. :cheers:
Bob
Just got off the phone with Tire Rack. Changed the size and also went with the Bridgestone Potenza S-O3 Pole Position. Thanks for the advice.
Bob
[Modified by 16Again, 9:13 PM 7/1/2002]
[Modified by 16Again, 10:31 PM 7/1/2002]
Old Jul 1, 2002 | 11:10 PM
Adman's Avatar
Adman
MySea5 knows his stuff! Especially when it comes to tire and wheel combinatiions. Pick his brain as much as you can! He's Da Wheel Man :cheers:
Matthew
Old Jul 1, 2002 | 11:20 PM
16Again's Avatar
16Again
Default Re: Tire Size????? (Adman)
Matthew
Yes I agree, His advice was the reason for the change in my order. It will set me back a few days but I'm sure it will be worth the wait. :D
Bob
To Tire Size?????
