Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
Michelen date code?
Old Sep 28, 2015 | 07:33 PM
whichvette's Avatar
whichvette
Default Michelen date code?
5u 4m 001x how old are these tires?
Old Sep 28, 2015 | 11:52 PM
Vette_DD's Avatar
Vette_DD
Wrong characters. Federal law says they're XX YY, where XX is the week of the year and YY is the last 2 digits of the year.
Old Sep 29, 2015 | 07:11 PM
whichvette's Avatar
whichvette
I will look again. All I saw was that and the size
Old Oct 4, 2015 | 02:43 PM
whichvette's Avatar
whichvette
Default Pilot sport 275 40 zr17
Date code 1109 November 09 I guess tread is good. When should they be replaced .drive about 5k a year
Old Oct 4, 2015 | 09:00 PM
ROBMARZ's Avatar
ROBMARZ
That's the 11th week of 2009. Pretty old rubber.
Old Oct 4, 2015 | 09:17 PM
whichvette's Avatar
whichvette
New tires would be much softer I'm guessing
Old Oct 6, 2015 | 11:14 AM
Luke@tirerack's Avatar
0Luke@tirerack
Former Vendor
St. Jude Donor '11-'12
Determining the Age of a Tire
When it comes to determining the age of a tire, it is easy to identify when a tire was manufactured by reading its Tire Identification Number (often referred to as the tire's serial number). Unlike vehicle identification numbers (VINs) and the serial numbers used on many other consumer goods (which identify one specific item), Tire Identification Numbers are really batch codes that identify the week and year the tire was produced.
The U.S. Department of Transportation (DOT) National Highway Traffic Safety Administration (NHTSA) requires that Tire Identification Numbers be a combination of the letters DOT, followed by ten, eleven or twelve letters and/or numbers that identify the manufacturing location, tire size and manufacturer's code, along with the week and year the tire was manufactured.
"When it comes to determining the age of a tire, it is easy to identify when a tire was manufactured by reading its Tire Identification Number (often referred to as the tire's serial number)."
Tires Manufactured Since 2000
Since 2000, the week and year the tire was produced has been provided by the last four digits of the Tire Identification Number with the 2 digits being used to identify the week immediately preceding the 2 digits used to identify the year.
Example of a tire manufactured since 2000 with the current Tire Identification Number format:
DOT U2LL LMLR 5107
51 Manufactured during the 51st week of the year
07 Manufactured during 2007
While the entire Tire Identification Number is required to be branded onto one sidewall of every tire, current regulations also require that DOT and the first digits of the Tire Identification Number must also be branded onto the opposite sidewall. Therefore, it is possible to see a Tire Identification Number that appears incomplete and requires looking at the tire's other sidewall to find the entire Tire Identification Number
The use of a partial Tire Identification Number on the one sidewall reduces the risk of injury to the mold technician that would have to install the weekly date code on the top sidewall portion of a hot tire mold.
To Michelen date code?
