C7 ZO6 Wheels Question
I have a C7 ZO6 w/ZO7. Im looking at the Cray Mako wheels. My stock wheel sizes are 19x10 and 20x12. Fronts I dont have a problem with. Its the rears. I want a 19" wheel because tire selection sucks in 20's and also I want a bigger sidewall for drag use. So I am looking at a 19x11 or 19x12 for the rear. When you go to the fitment guide for the ZO6 they only list a 20x12 for the rear with a 41 offset. But if you go to the Z51 fitment guide they list a 19x11 for the rear with a 76 offset. Will the wheel fit and what would be the difference? Will the 19x11 with a 76 offset sit in too much? Thanks for any help
PK Auto Design (08-23-2017)
Supporting Vendor
The answer is no, the GS Z06 ZR1 applications require a much lower offset then the Base/Z51 package so the fitment will not work.
You want to aim for a wheel that is a 12" ET 50 for proper fitment.
__________________
