stingray wheel question slicks/18s
I am looking to find a pair of rear rims that i can use as drag rims for my C7 base. i know many people consider C5Z rims as a preferred set of drag wheels for the c7 Stingray. I found rims that are aftermarket made for the C5Z06. The dimensions of the aftermarket wheels are not exactly the same as the stock Z wheels. Can anyone tell me if the aftermarket size rim will work even though the offset and the backspace are a little different from stock c5z size?
I am hoping to put 305/35/18 MT STREETS on the new rims. Any assistance that can be provided is greatly appreciated.
RIMS I WANT TO WORK:
Backspacing: 7.95
Bolt Pattern: 5-120.65
Hub Bore: 70.3 Rim Diameter: 18
Rim Width: 10.5
Offset: 56.0
STOCK Z06
Offset: +58mm
Back Spacing: 8.03”
Thank you -
Backspacing: 7.95
Rim Width: 10.5
Offset: 56.0
STOCK Z06
Offset: +58mm
Back Spacing: 8.03”
Thank you -
