Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
Does aluminum rust?
Old Jul 2, 2022 | 08:52 AM
fake's Avatar
fake
Default Does aluminum rust?
What is with the porosity of GM wheels? Are the molds just dirty when they are being made or is there a chemical affect with the treatment of the roads in winter?
Old Aug 9, 2022 | 03:16 PM
Fmmrz5's Avatar
Fmmrz5
Rust is Iron oxide. aluminum is a metal alloy. 6061 is the most common alloy used in wheels. That contains mostly aluminum, chromium, copper, magnesium, zinc, silicon, and yes iron. Very little iron and it is locked away so you wont get Iron oxide. but aluminum will corrode and form aluminum oxide. This is just the metal interacting with the oxygen molecules in the air. All aluminum wheels, and steel wheels for that matter, must have a coating (paint, powder coat, etc) to prevent oxidation. rock chips and other environmental factors can degrade that coating and allow the oxygen to interact with the bare aluminum and you'll get an oxide. So its nothing to do with porosity or dirty molds. just chemistry and failed coatings
