Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
Tire Patch ?
Old Aug 17, 2003 | 02:04 PM
96KICKS's Avatar
96KICKS
CI 7-8 Veteran
St. Jude Donor '03-'04-'05-'06-'07
Default Tire Patch ?
Hey guys,
How reliable is a patch? I got a nasty razor blade in my Goodyear Eagle F1, had the tire patched, and seems to be doing fine, but I really want to double check with all you experts.
Thanks! :chevy
Old Aug 17, 2003 | 04:23 PM
phxraptor's Avatar
phxraptor
Default Re: Tire Patch ? (C4Girl1996)
A patch on the inside of the tire if done right is ok. You can not patch a tire where the puncture is to close to the sidewall where flex of the tire occurs. Hope this helps. :cheers: :seeya
Old Aug 17, 2003 | 10:28 PM
lostsoulny's Avatar
lostsoulny
Default Re: Tire Patch ? (phxraptor)
patching from the inside is the proper way and I believe only way to maintain a tires original warranty and speed rating. if it is on the sidewall though the tire is shot :iagree:
To Tire Patch ?
