Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
lptws problem
Old Nov 16, 2003 | 10:01 PM
sultan's Avatar
sultan
Default lptws problem
haw can i fex this problem the lite is comming on after i drive the car
i red in the owners manual that u can cancel this haw can u do that please help
:cheers:
Old Nov 17, 2003 | 12:45 PM
wamara's Avatar
wamara
Cruise-In II Veteran
Default Re: lptws problem (sultan)
Are you not using the tire pressure sensors at all, or are you using them but having a problem with them? If you're looking to shut off the warning system, I think (I'm not positive though) you have to have an '01 or later car. You would use a Tech II (a diagnostic programming/scanning tool which a dealer would have) to deactivate this function.
