happy new year all.
If I go to a 18/19" set up will i lose ground clearance? Something tells me i wont be able to make that little dip into my garage....
thanks
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Re: Wheel question.... help please (dallasvette)
Go to 18/19" from what??
What size tire are you going to put on those wheels??
What were the old tire sizes??
Too many unknowns to give an accurate answer....
I would suggest a 275/35/18 front and 295/35/19 rear. The front tire is almost identical in height to your stock 17" tire, and the rear is slightly taller than stock, so there would be a very slight gain in ground clearance.
