I just installed a set of 2001 factory 5-spokes and EMT's on my '02 'Vert and am receiving "service tire monitor system" display with XXX readings where the pressures should be.
Is there a difference in sensors from my '02? Any help or suggestions would be much appreciated.
Thanks,
Dan
The sensors are the same and will work on your car, but you need to program the new sensors to the car. The car will only recognize 4 sensors, and anytime you change one (or all of them in your case), or even move sensors to a different location on the car, you need to do the programming procedure. You can do this yourself, it's very easy, all you need is a magnet, and these instructions: https://www.corvetteforum.com/techti...D=77&TopicID=1
