Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
Need wheel sensor modification info!
Old Oct 10, 2004 | 10:05 PM
Rob4092xx's Avatar
Rob4092xx
Default Need wheel sensor modification info!
Will wheel sensors on wheels taken from a 2002 C5 work on a 2000 C5?
I know 2000 wheel sensors will not work on a 2002 DIC, but is the reverse the same?
I am purchasing some wheels and tires from a 2002 C5 and am hoping the wheel sensors will work on my 2000's DIC?????
I have heard the valve stem holes are different sizes. Is there a modification to make my 2000 sensors fit in the 2002 wheels?
How hard is it to break the side of the Run-Flat tires down to get to the sensors so I can switch them?
If they are different in size or weight, will the tire need to be re-balanced????
Can anyone provide me with the part information necessary to make the 2000 sensors fit into the 2002 valve stem holes?
Thanks!
Old Oct 11, 2004 | 01:43 AM
wamara's Avatar
wamara
Cruise-In II Veteran
Rob, I do believe that the design of the sensor was changed beginning in the '01 model year, thus an '02 sensor will not function in an '00. The electronics are simply not compatible; it's not just the different valve stem grommets.... Sorry.
Old Oct 11, 2004 | 10:38 AM
Allthrottleandsomebottle's Avatar
Virginia Events Coordinator
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
NCM Ambassador
Yup...........1997-2000 are the same.
Old Oct 11, 2004 | 01:09 PM
Rob4092xx's Avatar
Rob4092xx
That is what I figured....
Since I still have the 2000 wheels and sensors mounted in them, can I take the sensors out and re-mount them in my 2002 wheels?
In other words, will my 2000 sensors fit in my 2002 wheels or do I need to make some type of modification in the valve stem hole?
Old Oct 11, 2004 | 05:27 PM
EVIL_C5's Avatar
EVIL_C5
Uber Waxer
Cruise-In 8-9-10-11 Veteran
CI 9, 10 & 11 Car Show Winner
St. Jude Donor '08-'10
so 2004 sensors wont work on a 99?
Old Oct 11, 2004 | 07:51 PM
Corvette Poor's Avatar
Corvette Poor
1997 - 2000 sensors will ONLY work on those year cars
2001 - 2004 sensors will ONLY work on these year cars
Old Oct 12, 2004 | 06:43 AM
Cruise-In V Veteran
NCM Ambassador
As far as I can tell ( didn't get ruler out) wheel dimensions for sensor mounting from 1997-2004 are the same. I have put 1997-2000 sensors on a 2001 wheel w/o issue.
The nut height is a little different between the 2 models sensors but does not effect mounting them
Old Oct 12, 2004 | 12:23 PM
Rob4092xx's Avatar
Rob4092xx
How about the difference in weight (was there any?)?
If there was, did you have to re-balance?
Old Oct 13, 2004 | 06:46 AM
Cruise-In V Veteran
NCM Ambassador
I had them swapped when I put tires on...........you could run them and see if you get any vibtation. Both sensors are light so it may be ok.
To Need wheel sensor modification info!
