Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
Numbers Question
Old Oct 31, 2004 | 12:01 AM
JeffMc's Avatar
JeffMc
Default Numbers Question
Could someone do a quick explaination of the numbers?
Front: 265/40 17
Rear: 295/35 18
Which are important?
I am looking at some Pilots A/S for the some winter driving in my Z, however I cannot locate my exact sizes.
Thanks Guys!
Old Oct 31, 2004 | 04:17 AM
BAM92's Avatar
BAM92
265/40/17 means that the width of the tire is 265mm and the sidewall height is 40 percent of the width and it is mounted on a 17 inch tire. Go to tirerack.com to find out specifics like total radius etc. in figuring out what tire will match the ones you are looking.
Old Nov 3, 2004 | 04:40 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
The only number that must be exact is the wheel diameter (17" and 18" in your case)... the section width and height can be slightly different and it won't hurt anything.
Larry
Old Nov 4, 2004 | 01:51 PM
JeffMc's Avatar
JeffMc
Thanks. This helps a bit.
To Numbers Question
