Wheels & Tires Corvette Wheel & Tire Sizing Info, Staggered Fitment, Tread Compound, Tire Pressure, size option
offset on wheels
Old Dec 23, 2004 | 12:39 PM
uforic C5's Avatar
uforic C5
Default offset on wheels
thinking of installing 275/35/18x8.5 on front of my 98 C5, stock offset on wheel is 56mm new wheel has a 45mm off set will this fit???
Thanx....
Old Dec 26, 2004 | 10:49 AM
1stC3Vette's Avatar
1stC3Vette
The 11mm difference will cause the wheel to stick out about 1/2" towards outer side of the wheel well. Take a look and see how you think it may look. You could jack up the car and space out your current wheel with washers to get a rough idea.
I am going to be putting on some 19"x10.5" C6 wheels with a 79mm offset on my C4. I need to use a 1" adapter to make it work.
Good luck.
Dino
