Soler Performance – C7 ZR1 Upgrades
Throttle body upgrades remain a simple way to support airflow and throttle response.
95mm Throttle Body: https://www.solerengineering.com/generalmotors/95mm
103mm Throttle Body: https://www.solerengineering.com/generalmotors/103mm
-Tiffany
Soler Performance
Discount Code: TIFF5OFF
Text/Call: 251-468-9786
support@solerengineering.com
Tech support: 251-716-8077
General questions and sales: 251-468-9786
-Tiffany
Soler Performance
-Tiffany
Soler Performance
• Does the display have a lock mode?
No. Once paired through Bluetooth, you can remove the display and keep it in the glovebox or at home if preferred.
• Does the controller need calibration or update recovery?
No. It’s plug-and-play and works with the factory system automatically, including with other bolt-on mods.
• Can I unplug the display while the car is on?
No. Only disconnect or reconnect the display with the vehicle fully off and in sleep mode.
• Does the controller itself have to stay installed for the app to work?
Yes. The controller must remain installed and powered on. Only the display can be removed.
• Can the controller/wiring be hidden?
Absolutely. Most customers tuck everything behind dash panels or carpet trim.
• Does my phone need to be near the car for Bluetooth?
Yes. You’ll need to be inside the vehicle with it powered on.
• Where do I find the 4-digit pairing code?
With the display installed:
Hold both buttons on the display and the code will appear.
Without the display:
Use the last 4 digits of the serial number on the silver sticker located on the small black box near the pedal assembly.
• The app won’t connect after denying Bluetooth permissions. Fix?
Delete the app, reinstall it, restart your phone, and make sure Bluetooth permissions are allowed during setup.
• Will current controllers work on the upcoming 2027 C8 Grand Sport?
We recommend holding onto your current DLX controller for now. We haven’t fully tested the new Grand Sport yet, but compatibility is very likely.
• Does the controller override factory drive modes?
No. Tour, Sport, Track, etc. still function normally. The Soler controller operates independently and adjusts throttle sensitivity separately through the display or app.
• Can multiple phones pair to the controller?
Yes. Multiple phones can pair, and it’ll connect to whichever phone opens the app first while in the vehicle.
-Tiffany
Soler Performance
