Grand Sport vs Z06 from rolling start?
From a low roll or off the stoplight, not wound up in launch mode, just normal driving, on a short burst, low rpms, the GS should walk from the Z06 easily. Same weight, same gearing, massive increase in torque, massive increase in HP at low rpms.
Roll racing? Z06 has the win easily. If I had to guess official numbers for the GS I’d say 125 mph traps official (Z06 gearing definitely will help). Z06 has hit 135 in good air on the fast list, and is listed at 131 on Chevy’s website.
In the end it’s power to weight (a=Fm), you can’t beat Newton. Z06 has 135 hp over the GS on the top end. The GS has the power advantage at the low end so if you’re in that range you’re taking a Z06 down. On a road course the Z06 is in its element and will easily put the GS down.
On the drag strip the Z06 still wins because you’re sitting in the Z06’s power band for the entire run. Now when you start factoring in higher gears, rolling starts, shorter runs, the GS will be pound for pound be a challenge for the Z06.
Does the GS have an advantage off the corner making 50 more ftlbs of torque at peak though?
It’s all speculation at this point but I just don’t think there’s a scenario where a GS would beat a Z06 on a road course. Possible GS advantage in autoX because you’re always in low gears and low revs. It’s power to weight in the end; any scenario where the Z06 is able to stay in its power band, it’s going to be ahead. It’s just a more powerful car top end.
Now ET?? Maybe it will be closer but the farther out you space the run the more the Z06 HP becomes more of an advantage. Burnouts would most definitely be easier to do in the GS, as well as launch mode where you most likely won’t need to use as much slip % or RPM to get the car to launch well.
Another hypothetical situation would be with regards 5th gear which we all know is really tall in these cars. When doing a long pull and hitting 5th there may be an advantage in the GS favor since it has more torque to pull that gear out, at least the Z06 wouldn’t pull as hard I would assume, but nonetheless it will still be ahead.
With respects to the original comment though, the GS should walk a Z06 on the low end of a roll or anything that puts the Z06 well out of its torque range. On the street day to day the amount or difference in power below 3k is pretty substantial (HP and TQ wise). Imagine being in 3rd at 2,500 rpm in the Z06 and leaning into the gas to pass someone without downshifting, and doing the same in the GS. The difference will be night and day.
If I’m on the street day to day I want the GS. If I’m going to the track I’m taking the Z06.
Agreed, the GS can be just as quick to 60 mph launching at a lower rpm and faster if launching at the same low rpm possibly.
With the GS having a lower rpm it will use 6th gear for top speed unlike the Z06 which uses 5th, so that will help it up top some though hp of the Z06 will still favor triple digits. I suppose things might be interesting from a roll between a Z07 and aero deleted Z51 as the latter will have substantially less drag.
Z06 takes 5th all the way to the top and hits the wall, GS grabs 6th and lugs it out for another 5 mph over the Z06; it’s entirely possible as the torque split at 3k is greater than the maximum HP split between the two engines.
HP = (Torque × RPM) / 5252
Where:
- Torque is in lb-ft (pound-feet)
- RPM is revolutions per minute
- 5252 is a conversion constant (derived from the definition of 1 horsepower = 550 ft-lb per second, plus the conversion from revolutions to radians).
- 1 horsepower = 550 foot-pounds per second.
- Torque in lb-ft × angular speed (in radians per second) gives power in ft-lb/sec.
- RPM to radians/second involves multiplying by 2π and dividing by 60, which simplifies to the factor of ~5252 when solving for HP..
- 300 lb-ft of torque at 5000 RPM → HP = (300 × 5000) / 5252 ≈ 285 HP
- 400 lb-ft at 6000 RPM → HP = (400 × 6000) / 5252 ≈ 457 HP
- Torque (lb-ft) = (HP × 5252) / RPM
