Rev Match Double Blipping Below 3.5k RPM
On the test drive, I immediately noticed something off with the auto rev match. At lower RPMs it does a weird double blip instead of a clean, single throttle blip. The previous owner mentioned it had done that the entire time he owned it (about 6,000 miles), but coming from my previous M7 2014 Z51, I knew that wasn’t normal. That car’s rev match was always smooth and precise, so this stood out right away.
Fast forward to now, the car has been amazing in every other aspect. It drives great, shifts perfectly, and overall has been a fantastic car. The only lingering issue is the rev match still not behaving correctly.
For reference, the car currently has a DSX lid, Chevrolet Performance CAI, Texas Speed headers and X-pipe, Cordes Performance ice box, Mighty Mouse catch can, and an MGW shifter.
Since owning it, I’ve also added a DSX flex fuel sensor and a DSX aux pump. Not sure if any of that is relevant, but I figured I’d include everything.
About a month ago, I took it to a well-known Corvette tuner here in the Indianapolis area. On an E56 blend, the car made 667 WHP. I brought up the rev match issue to him, and he verified the stock mapping in that area while building out the rest of the tune. The car runs excellent now, but the rev match issue is still unchanged.
I’ve also checked the spark plugs, and they all look healthy.
One other thing I discovered was that the car had a 91mm Soler throttle body installed. I’ve since swapped it back to the stock 87mm throttle body, but that made no difference either.
At this point, I’m kind of out of ideas.
Is this something that needs to be specifically dialed in through tuning at lower RPM, or am I chasing the wrong thing entirely, like a sensor or input issue?
Appreciate any insight, thanks for taking the time to read.
Bill
Bill
Bill
Bill
1. Clutch in and shift to neutral.
2. Clutch out and rev the engine to increase the input shaft speed.
3. Clutch in to downshift, hopefully without grinding,
4. Clutch out
4. Clutch out
Rev Match can avoid the scare and the embarrassment.
Bill
