Gen V BBC lifter question
Many years ago I built an engine with a kit from Comp Cams that included the Cam, hardware, valve springs, lifters and a double roller cam chain and the lubricant needed to use with the parts. This system worked well because they were made to work with each other.
It seems that (relatively mild) 11-412-8 comp roller is a RETROFIT version (Not intended for use with OE roller lifters).
Link-Bar lifters are typically for use with RETROFIT cams.
Seems GEN V BBC were produced with Either OE flat tappet lifters, Or with OE roller lifters.
There are both OE replacement roller cams AND RETROFIT roller cams.
If you post clear hi-rez pics of front face of block (with cam Removed), AND (with intake manifold Removed) of block's lifter valley; we can determine if your GEN V block is capable of hosting a OE-style roller cam with OE-style roller lifters.
Even when inconvenient, detail's required. GIGO
* FWIW, seems that 11-412-8 roller cam is ground on a Cast Iron core; Unlike all GM BBC & sbc OE Roller Cams (which are ground on much more robust SAE 5150 billet steel cores). Comp (& most others like it) offer same lobe profiles that're available ground on more than one core type material.
No matter what, all roller lifters Must have some means to prevent that lifter from rotating within its lifter bore. OE roller lifters have a pair of flats at lifters' shoulders that are keyed into a lifter guide (aka dogbone) which does prevent roller lifter from rotating within bore.
Aftermarket Retrofit roller lifters typically have Link-Bars; those to prevent lifters from rotating within their bores.
If your GEN V BBC motor Truly has OE roller lifters, it's also a near-certainty it has a "step-nose" cam as well; which uses an OE retainer plate at cam nose. Motors with OE step-nose retainer plate CAN use OE roller lifters (in conjunction w/ OE dogbones).
OTOH, motors without ability to use OE roller lifters must use a "flat-nose" cam and aftermarket Link-Bar roller lifters.
Again, a few good pics of YOUR block face and of YOUR lifter valley will tell the tale.
** for True max-effort race motors; there are also "keyway" Aftermarket roller lifters which (as the name implies) have keyed interface between lifter and bore. Those are an expensive consideration; to both purchase and for required machining & fitment to block.
Seems you're stuck using Retrofit Link-Bar lifters $$. Assume your comp roller cam has flat-nose; seems that's what'll mate well with your block.
However, You must verify that by inspecting the front face of Block and determining if it is drilled & tapped for a step-nose OE cam retainer plate.
Redardless, I don't see any way for the (cheaper overall) OE dogbone-spider hold down scheme to work with your block + OE roller lifters.
Post it here. Looking for two tapped holes about 3.5" center-to-center. But, after viewing pic of your block's lifter valley, I seriously doubt they exist in this block.
Regardless; it's clear your block does Not have the mounting points for the components that are required to fit OE Roller Lifters.
I just had an engine built by BES Bischoff although not the same engine as yours.
Link bar lifters was one of the few places they recommended I buy a more expensive version of the part. Mostly they helped me to not spend money on things that weren't really useful for my build.
And, Good Link-Bar Roller Lifters are MUCH more expensive than are Good OE Type Roller Lifters.
There are bargain-basement chinesium lifters being traded underneath nearly every rock; run.
Don't skimp on valvetrain quality.
