Autocrossing & Roadracing Suspension Setup for Track Corvettes, Camber/Caster Adjustments, R-Compound Tires, Race Slicks, Tips on Driving Technique, Events, Results
C7 GS RE71 RZ pressures
Old Apr 6, 2026 | 09:45 AM
smitty2919's Avatar
smitty2919
Default C7 GS RE71 RZ pressures
First autocross this Sunday with my new to me 100% stock suspension/alignment C7 GS with 315/335 18's RE71 RZ. Last car was a C5Z with 315x18 square RT660's I ran around 32FR 30RR
Just looking for some ballpark pressure recommendations. My normal approach I found worked has always been the rear pressure was 2psi lower than fronts and to eyeball the wear around the shoulder given the course setup that day.
Old Apr 6, 2026 | 12:07 PM
LT4_FTD's Avatar
LT4_FTD
On my C5Z I ran 26-28 psi to start and ended at 28-30 at the last autocross, and it worked ok. This was 315 square, around 3450 lbs with driver.
Old Apr 6, 2026 | 12:21 PM
JRL's Avatar
JRL
I run 295/30/18-335/30/18 RZ's, cold 28/28, hot 30/30, C7 Grand Sport, stock suspension except for AFE Front Sway bar.
Old Apr 6, 2026 | 01:23 PM
smitty2919's Avatar
smitty2919
Awesome, thanks. Have you tried staggered pressures? Or reason behind front/rear the same?
Did you notice a big improvement with larger front bar? I did similar on my C5Z running a C6 Zr1 front bar being the largest factory bar that would bolt on. Worked well, cheap too lol
Old Apr 6, 2026 | 01:33 PM
JRL's Avatar
JRL
I do autox and time trials on track. I had both AFE F/R bars, felt good, then added 2650 Magnuson S/C, so went back to stock rear bar to settle down the rear and put down power better.
I've run C5Z06 for 10 years, always ran 2 psi more in front, I starting running equal pressure with C7GS for track 25/25 cold, didn't want to go lower in the rear to set off TPMS warning, and it works. But 30/28 should be good for autox, too.
Old Apr 8, 2026 | 10:04 PM
PRE-Z06's Avatar
PRE-Z06
How do you like the new RZ’s and what width wheels do you have them mounted on?
Old Apr 8, 2026 | 10:06 PM
PRE-Z06's Avatar
PRE-Z06
I also ran lower rear psi than front with staggered tires because if the car has 50/50 weight distribution then the narrower fronts have more weight per sq in I figured though I also ran slightly more camber in the front than rear. What width rims do you have the 315/335 tires mounted on?
Old Apr 9, 2026 | 08:54 AM
smitty2919's Avatar
smitty2919
18x11 front and 18x12.5 rear. Stock alignment and stock ride height.
My normal "simple approach" is to see where the tire wears/rolls over given the current course layout and adjust pressures based on that also factoring in how it feels and it does what I want/expect which increases confidence to push.
I do have a pyrometer to be "technical" but it rarely comes out. My past C5Z on triple adj coilovers had more ***** to tweak. This car is 100% stock suspension so, toss it in Race mode and do away with any nannies and let it eat.
Old Apr 9, 2026 | 09:07 AM
PRE-Z06's Avatar
PRE-Z06
I like it and I have the same wheels, was debating on whether to go 315’s or 295’s up front. Have run 295 RE71RS and A052 on 10” and 305 RE71RS and 315 CRS on 11” wheels, but not 295’s on 11” though thinking back my C5FRC had 295 on 10.5” in the rear originally.
Old Apr 9, 2026 | 10:23 AM
smitty2919's Avatar
smitty2919
I will stuff as much tire as I can. Some school of thought is a lack of response with a tire that is pinched (315 on a 10.5). And that makes sense.
I also hate the stretched look but that seems to be the more “optimal” approach.
My C5z was 315 square on 10.5 RT660’s also to be able to rotate. The GS I have found many say stick to a staggered while also not deviating TOO far from OEM diameter so all the drive modes remain relatively happy.
Old Apr 9, 2026 | 11:38 AM
PRE-Z06's Avatar
PRE-Z06
I don’t like the stretched look mostly because it doesn’t protect the rim, but pinched tire could just be more rotational weight which isn’t good.
I’m not concerned about stability control as I turn it off, but do want to keep ABS happy and feel the car handles better with a stagger personally.
Old Apr 9, 2026 | 12:34 PM
AHP's Avatar
AHP
Really interested hearing how these tires work out on track for C7 GS/Z06. I was tempted to buy a set but decided to hold off and wait for some reviews.
Old Apr 9, 2026 | 02:19 PM
smitty2919's Avatar
smitty2919
From what I gather within my crowd/group...they are preeeety good. Reported to be better than the RT660's I had before.
Nankang CRS are also pretty good.
Old Apr 9, 2026 | 02:24 PM
AHP's Avatar
AHP
Nankang CR-S v2 and Supercar3R are my current go-to for HPDE so glad to have a new entrant in the same sizes I run. 305/30/19, 325/30/19 Hoping they're as good or better than CR-S. I really liked the RE71RS on other cars, but they never came in the sizing I needed for the C7Z.
Old Apr 9, 2026 | 02:38 PM
smitty2919's Avatar
smitty2919
Yep, that's why I went down to 18's.It was an ordeal going through my head. 18 square...18 staggered...19 square...19 staggered...18/19 combo...
Old May 7, 2026 | 01:45 AM
Bschwingy's Avatar
Bschwingy
How do you like the tires? Im on a hunt for which ones to run. Thank you
Old May 11, 2026 | 09:36 AM
smitty2919's Avatar
smitty2919
I like them so far.
First event I ran 29psi square and the second event I ran 32FR/30RR and may stick with the 32/30 going forward. They give a little audible feedback if pushed too hard which I like.
No complaints so far on 2 events.
Old May 11, 2026 | 11:55 PM
JRL's Avatar
JRL
Sorry, just saw this.
I love the RE71RZ, 18x11 front/ 18x12.5 rear wheels, 335 RZ puts power down like my 315 A052's. and wear is better.
Old May 12, 2026 | 12:56 AM
Bschwingy's Avatar
Bschwingy
Awesome to hear, im gonna give these a try. Thank you
To C7 GS RE71 RZ pressures
