OldCarBum's '73 Restomod Project
Old Apr 30, 2026 | 09:09 PM
  #2321
The Phantom's Avatar
The Phantom
Nice career … but what we really want is a pic of the valve that causes the issues, getting back to the original post, lol.
Dave
Old May 1, 2026 | 11:50 PM
  #2322
OldCarBum's Avatar
OldCarBum
Ok, OK!!!
This is the heater control valve that has given some people issues with the Generation IV VA system.
Apparently they are using this same valve in the Generation V systems however the valve is now exercised every time the car is started and not just when you turn on the heater.
VA says they haven’t seen any failures with the valves in the Gen V systems.
Earlier revisions of this valve were the cause of failures and were discussed in several older threads.
Old May 2, 2026 | 01:38 AM
  #2323
OldCarBum's Avatar
OldCarBum
Today I installed the new Red Horse Performance manual heater bypass valve, I made up and installed the braided heater hoses.
I was able to hide the new valve under the other heater line that comes through the firewall.
Old May 2, 2026 | 02:09 AM
  #2324
4-vettes's Avatar
4-vettes
Cruise-In VIII Veteran
Very tidy heater shut off install. But begs to question, do you even need heat in California?
Old May 2, 2026 | 12:26 PM
  #2325
OldCarBum's Avatar
OldCarBum
Depending on where you live, it is possible.
So Cal you need ac all year.
Nor Cal we have four seasons, although spring and fall may only last a week or two between summer heat of over 100 and winter cold into the 40’s and 50’s.
You can actually surf in the morning at the beach and then be in the mountains snow skiing in the afternoon.
Old May 3, 2026 | 12:04 AM
  #2326
OldCarBum's Avatar
OldCarBum
This should confirm my OCD and how you probably all think I’m nuts.
After I changed out all the hoses in the engine bay from RedHorse Performance rubber to steel braid, I stood back and did not like the look at all.
Steel braid is nice and I’ve used it in many other builds but it’s not the look I’m going for this time.
So I removed all the steel braided hose and replaced them with the RedHorse hoses.
Old May 3, 2026 | 07:25 AM
  #2327
Rescue Rogers's Avatar
Rescue Rogers
Is my vette stock?? HAHA
2016 C3 of Year Finalist
Cant argue with your decision, she looks beautiful!!
Old May 3, 2026 | 09:00 AM
  #2328
The Phantom
Ok, OK!!!
This is the valve that I replaced my systems original solenoid style unit with, the solenoid style when operated got extremely hot, not really an issue if its in the engine bay i guess but I have it located under the dash. I will keep an eye on it, but I haven't noticed any noticeable power draw, then again I generally use my kill switch when the car is sitting.
Dave
Old May 3, 2026 | 11:46 AM
  #2329
OldCarBum's Avatar
OldCarBum
Thanks!
Thats and older picture showing the rubber hoses since then I’ve moved the fuel pressure regulator off the firewall and attached it to the end of the fuel rail so the one braided line going to the firewall has also been deleted.
Old Today | 12:39 AM
  #2330
OldCarBum's Avatar
OldCarBum
I received the correct ac hard lines from Vintage Air.
I installed the lines and the drier so now I can order the upgraded reduced barrier hoses and necessary fittings.
Old Today | 07:16 AM
  #2331
HawkRod's Avatar
HawkRod
Looks good. Looks clean and nice like everything else on your car!
Make sure your A/C system is totally sealed since you put the drier in the system - otherwise humidity will seep into the system and destroy the desiccant.
Old Today | 10:18 AM
  #2332
leigh1322's Avatar
leigh1322
Old Pro Solo Guy
If they actually have any humidity in No. California!
It is certainly different than the always humid east coast.
Engine bay looks like a show car OCB.
Gorgeous.
