Drag Racing Results, Trap Speed, Reaction Time, Driving Technique, Tips for Running the Corvette in the ¼ & 1/8 mile, Events
Hoosier DR2's vs ET Street R's Need Help Deciding!
Old 08-27-2017, 11:36 PM
emoFTW
emoFTW's Avatar
Default Hoosier DR2's vs ET Street R's Need Help Deciding!
Which tire have you guys had good luck with? I'm torn between the two. The size will be 275/40/17 and will be going on a manual trans car. Cam only ls3. Looking for the tire that will be best at the track. I would prefer to run a BP tire for the track, but I know there are no options at 26". Car doesnt make enough power for 28" BP tires.
Old 08-28-2017, 10:58 AM
dieselracer
dieselracer's Avatar
I think a Hoosier 28x10r17 slick would be the way to go. Since you are a stick you want a soft side wall. The Hoosier 28 slick are not actually 28. they are more like 27.5 ro 27.8 I run that on my stock ls3 auto with great results. I guess also depends on the track you go to. My track has about the same traction as the street.
Old 09-19-2017, 08:02 AM
C5Natie
C5Natie's Avatar
Im looking at these myself. The bias ply's right?
Old 09-19-2017, 07:51 PM
dieselracer
Originally Posted by c5natie
im looking at these myself. The bias ply's right?
yes, but like all slicks they do grow. So they might rub. So you might have to raise the rear to keep them from rubbing.
But they hook very well. All depends on the track you go to and how well prepped it is.
Old 09-19-2017, 11:22 PM
GARY2004Z06
GARY2004Z06's Avatar
A 275/40R17 DR will work; however, as you stated a bias ply would be a better option. You may wish to consider modifying your spindle and go with a 16" option such as the M&H 26/11.5-16.
http://www.mandhtires.com/M-H-Racema...T#.WcHctbpFw2w Note: M&H is currently out of stock but you may be able to locate it.
I do also agree that the 28" will not work optimally for your setup. Your standard gearing and lack of power will provide less than optimal results on the launch as well as the big end.
Old 09-19-2017, 11:27 PM
GARY2004Z06
If you do go DR, the Hoosier is lighter and will provide great traction.
Old 09-20-2017, 07:44 AM
C5Natie
C5Natie's Avatar
Yeah thats my plan. Im on coilovers so I can raise the rear to keep the slicks from rubbing. Thanks
Old 09-20-2017, 11:05 AM
dieselracer
yeah thats my plan. Im on coilovers so i can raise the rear to keep the slicks from rubbing. Thanks
if you can get away with a drag radial then what would be a great option. Where do you plan on racing? A shorter tire will not help if you can't get it to hook. I race at a track with basically no traction. So I have no choice but to run a full slick.
Old 09-21-2017, 12:25 AM
C5Natie
C5Natie's Avatar
Well we're pretty much down to only one 1/4mi track in Southern CA (Fontana). The prep is usually not that great. Sometimes you get lucky on a test and tune day and theyll lay some rubber and vht but on most street legal days it aint great. Im trying to hook 900rwhp as well which can be challenging. I run C6Z brakes which limits my rear wheels to no smaller than 17".
Old 09-21-2017, 12:30 AM
C5Natie
C5Natie's Avatar
Also the car is really setup for autox and stuff. The coilovers and fat sway bars make the car pretty stiff and even though I can soften up the rear shocks I thought maybe a tall bias ply tire can work as part of the suspension and help the car squat on launch.
Thats another thing too, seeing if a sifter or stiffer rear setting will work with 28" bias ply slicks.
Old 09-21-2017, 01:41 AM
dieselracer
my vote Would be 28×10r17 hoosier slicks. They hook great.
C5Natie (09-21-2017)
Old 09-21-2017, 01:56 AM
C5Natie
C5Natie's Avatar
Thanks. Those were on my list and you have now helped me make a decision.
Old 09-21-2017, 11:03 AM
dieselracer
Make sure you post your results. So far the guys I know have tried them have liked them, but Don't like the fact they have to raise the rear or they rub the liner. Remember they grow. So if you can test them on the street to make sure they are not rubbing.
Also if you are going tubeless which we all have. Make sure you have steel valve stems, and have them mounted with hairspray too.
Old 09-24-2017, 02:09 AM
C5Natie
C5Natie's Avatar
Will do. Thanks
Old 09-25-2017, 02:25 AM
Kouasupra
Kouasupra's Avatar
Hoosier hands down the best out of the two you mention. This is just my personal experience.
Old 11-28-2017, 11:12 AM
dieselracer
will do. Thanks
any updates?
To Hoosier DR2's vs ET Street R's Need Help Deciding!
Quick Reply: Hoosier DR2's vs ET Street R's Need Help Deciding!
